Tundra
Re: Tundra
Also debating on if I want to plastidip my wheels while I have them off just for something different.
Re: Tundra
i did that exact thing with my first stealth wheels. looked good IMO but i used actual wheel paint. it was before plastidip was a thing
Re: Tundra
I dipped the mustang wheels and the volt wheels. Both lasted well. I have like 5-6 cans of the stuff in the garage still.
Figured if I end up liking it, once it peels, I can just remove it and use actual wheel paint.
Re: Tundra
When I had the dash out I saw there are plugs/wires going into the blank spaces for switches under the hvac controls. In the owners manual those are for the heated seats. I wonder if I found heated seats if it is already wired for it then?
Re: Tundra
Tough to say without seeing the factory wiring diagrams. The dash may be wired for it, but the body harness that connects to the fuse box may be missing critical bits.
I'd start by checking the owners manual to see where the heated seat fuse is, and then see if you have that fuse populated. Or at least if both terminals in that fuse location are populated.
On both my Ford and Chevy stuff I've seen some fuse locations that have the common positive terminal populated, but the other side that would go to the actual load is missing from the harness.
Re: Tundra
Re: Tundra
I've actually looked at those a lot. I also really like these
https://www.demello-offroad.com/tundras ... -2007-2013
But after adding shipping, tax, winch, etc it's like $3500. Lol
Re: Tundra
i bought a welder recently, i plan on doing the full coastal set on the lexus. Looks like a fun project to learn.
Re: Tundra
Obviously I'm all about DIY, but wouldn't it just be easier to buy one that's ready to go? It seems like constantly taking it on and off and trying to keep everything lined up would turn into a hassle really fast.
Re: Tundra
Good bumpers are way more expensive. Most people just tack it up on the car then pull it off for final welding
Re: Tundra
Ya. You can buy cheap ones on ebay or Amazon. But quality bumpers are usually north of $2k before even considering shipping or taxes.
Re: Tundra
Rear bumpers are insane once you factor in swing outs and stuff. The coastal kit is $1800 with all the options and that’s still diy without welding or coating.
Re: Tundra
Small changes make big differences.
Before
After
Will be debadging the rest of the truck this weekend.
Before
After
Re: Tundra
Debadged it. Still waiting for one last part of the lift kit to arrive then I'll get it on. Hopefully in the next week or so.
Re: Tundra
Re: Tundra
I can get one for $100. The grille that is.
As for power, I don't want more in it actually. Maybe a little growl from exhaust eventually but it's so smooth right now I don't want to add more power.
Re: Tundra
Jeff V. wrote: ↑Fri Mar 21, 2025 2:48 am![]()
Also, inexpensive paintable grille for you.
https://www.amazon.com/Compatible-Tundr ... FD2YH?th=1
