Bought a Miata...
Re: Bought a Miata...
i didnt put a new one on, i was debating but didnt want to spend the money. It was a cheap one though, and i tensioned it too tight.
That's a tensile break, and is a direct result of over tensioning the belt. :)
yeah, happened during a hard 2-3 shift, so im assuming when i tried to get back on the power and clutched out it was just like fuck this shit im out.
[quote=""tabasco122""]yeah, happened during a hard 2-3 shift, so im assuming when i tried to get back on the power and clutched out it was just like fuck this shit im out.[/quote]
Yeah, also because a used belt should be tensioned less than a new belt as well, so it was probably severely over tensioned.
It only had a few thousand miles on it, so i figured it would be good. Plus i spend a few hundred on the top and door cards, so i was trying to be cheap.
How'd you over tension the belt? It's just a spring and then tighten the bolt holding the pulley in place.
[quote=""Chris GTO TT""]How'd you over tension the belt? It's just a spring and then tighten the bolt holding the pulley in place.[/quote]
He put additional pressure on the spring
It looked loosey goosey, didnt think about the fact that it really only needs to be tight on the exhaust cam side.
:facepalm:
Probably should have read a guide or something, but its just a miata ;)
You done butt fucked that car!
Non inteference, it's probably fine. $26 for a gates belt and an hour of my time.
Did you really try and save 26 bucks? I was thinking 100. Lol
It was just replaced less than 5k miles ago along with the water pump and some other things.
[quote=""DCIV""]Did you really try and save 26 bucks? I was thinking 100. Lol
Honestly, the belt would have been fine if he weren't retarded. :p
It would have been just fine had been not put extra tension on the belt... Hell I'm putting my 5k old timing belt back on, but I am not putting any extra pressure on it than the spring does.
miata runs again, now do i use tomorrow to install the projectors and HIDs or do i work on the forester...
Forester.
These threads need better titles...
[quote=""vegasidol""]These threads need better titles...
That was the point lol. Greg Chris and I all bought miatas around the same time. Pretty sure there are a few more that people made in jest.
