This can only end poorly
Re: This can only end poorly
It only took me about 20 min. And that includes removing the wheel, caliper, ebrake line, upper control arm, and axle nut. Just needed to pop a pry bar in between the diff and cup and a gentle push and it came right out.
mine was nothing to get to, i think i just had to disconnect the control arm, it was just stuck
I ended up putting a slide hammer weight on some allthread threaded into some vice grips lol
Probably the last one of the season.
https://imgur.com/a/AvFGWPx#bfLwPro
Didn't hit the track last night. They were requiring drag tires only. No street tires. Pain in the ass track if you ask me. Guess I'll have to wait until next year.
Almost done with the season of driving it. Maybe a couple of weeks left.
I'll do an oil change in the spring but wondering if there is anything else I can do to it during the winter.
Unless I pick up wider fenders and better seats, I'm not sure if there is much to do at this point.
Yea, im in the same boat. Not too many weeks left before i park the Chally.
Meanwhile this is the time of the year where driving the WRX is fun
Is your car set up to run E85? I can't remember. Maybe look into doing the sensor setup to enable that if you don't have it already?
its near impossible to get here in WA
at least not at a station
What he said. I could have done it when I got the procharger put on, but damn near impossible to get here
i live maybe .5mm above the "t" in portland, about 6 miles from the one station in portland, and will not go down there for e85
I live at the right dot and work at the left dot. There’s 2 stations in the town I work in that aren’t on that map for some reason.
https://imgur.com/a/LeiYQEP
There is 1 by me. Maybe when I get my cam, torque converter, etc done I'll have them set me up for it. But that won't be for another year or two. Expensive.
It would be the btr cam, cam kit, btr top end rebuild, rocker arms, smaller pulley, flex fuel kit, circle d converter, etc. Then retune the engine and transmission. Would put me to over reliable 700rwhp but would cost about $12k after paying for the labor and everything.
Didn't end poorly, but did sell it. Was able to sell it for almost $10k more than I paid for it.
Sold the Vette already? And for $10k more?
How much did you put into it?
$1.76 billion
