This can only end poorly
Re: This can only end poorly
It looks like a healthy stock AT LS3 should go high 300s. So you're getting 25-35 hp with the mods you already had. That's stout.
Mainline Pro Hub 2500
That is the dyno they use.Which isn't used much in the USA. Used a lot in Australia. Quick internet search shows it tends to read lower than others.
This just turned into a very fun car.
Should be on the dyno for final tuning Friday.
:vette:
Ooo. Shiny.
Duck Vader wrote: ↑Wed Oct 23, 2024 1:56 am Image
:lmao:
Fabricator was working on brackets and mounting the transmission cooler this morning and was going to get it plumbed this afternoon. The supercharger kit was almost finished, they just needed to install the boost-a-pump and injectors then give everything a good look over between tomorrow and Thursday.
Snail power to the rescue.
:heehee:
Lol.
Guess it's a good thing I upgraded them already.
Duck Vader wrote: ↑Thu Oct 24, 2024 2:29 am Lol.
:like:
Bit of a delay getting it back. Going to be another week. One of the other projects had a complication that took longer to fix than expected so had to bump my dyno day to Tuesday. Then they will drive it a couple of miles on Wednesday/Thursday to make sure everything feels good. I plan on getting it Friday Nov 1.
If Danielle can get half the day off we will go together. If not I'll have to rent a trailer.
Drive there to get it, drive it home. Go later to pick up other vehicle.
Weather is the issue now. 40s and rain. That won't have any traction.
It's also about 80 miles away and not a place I'd want to leave my other vehicle when I probably won't be able to go back until sometime in December.
