Ive changed the fuel pump and it sucked. Only because you cannot drain the plastic tank. Oh, the fumbling and workout that ensued.
Jeff i would look at injectors first, but it sounds like its a pain to gain access. Not a bad job for $90 and all new injectors though.[/quote]
I changed one on my old green XJ. Straps holding the tank were so rusted I didn't trust dropping it so I just cut a hole in the back and gained access from inside the jeep.
At 170k I would think about changing injectors just out of pure maintenance, and replacing anything else I could while I was in there.
