[quote=""DCIV""]I see nothing!
Same
[quote=""ChargerX3""]Same[/quote]
Where brian with his img’s are so easy post.
Works for me :d ontknow:
Doesn't show on my Iphone. Does on my computer though.
Looks like something off a F&F movie with chrome bits from Vatozone.
Works on my note9
Not only can't you post pics, but now you can't see them? LOL
Jeff that thing looks like a disaster.
That's probably why they went with a V8. :lol:
However, not everyone thought that way. I like this just for the blasphemy alone. 3rd gen Supra.
https://engineswapdepot.com/?p=2617
So this truck is still kicking butt...slowly. :lol:
I'm trying to figure out something that's been going on since we bought it. It's had an intermittent code for misfire on cylinder 2 (P0302). It'll go out, sometimes for a week or so at a time. Then pop back up for no apparent reason. I replaced the plugs and moved the coils around. The problem stayed on #2. I haven't done a compression test yet. It feels like it's got a slight hesitation above 3000rpm, but that could just be vibration due to the tires. It's pretty vague.
I would think if it was something mechanical, it would always be on. My only thought at this point is it's got a marginal fuel injector.
Any thoughts?
GM’s have horrible grounds. Just off the top of my head.
If there was a bad ground it would affect more than just one specific cylinder.
[quote=""Jeff V.""]If there was a bad ground it would affect more than just one specific cylinder.[/quote]
Agreed. I just know shitty grounds cause odd issues is all.
My first thought was injectors. Swap them and see if misfire moves.
I have to take the intake manifold off to get to them. If I go that far, I'm going to replace them on principle. The truck has over 170k on it, and I can get a full set of new ones for $90.
I'm tempted to do the fuel pump for the same reason, but it's a little more expensive at ~$250.
Another win for the XJ. Super easy to get to the fuel injectors. Only hard thing to get to is the fuel pump. Damn thing is in the gas tank.
Right before my fuel pump went out. I got the same code, two days apart that said it was running lean. Never felt it in the truck so I just shrugged it off.
It took me 9 months to condemn one of my customers envoy with bad intake valves. Swap coils, plugs, injectors, intake gaskets, etc. Finally caught it in the act and a vacuum gauge confirmed it.
Replace all 12 intake valves and no problems. Yes it's a somewhat common problem on the 2.8/3.5/4.2
Ours is a 3.7. They allegedly fixed the head problems late in 06, and carried those fixes on when they revised the engine from 3.5 to 3.7.
[quote=""Jeff V.""]Ours is a 3.7. They allegedly fixed the head problems late in 06, and carried those fixes on when they revised the engine from 3.5 to 3.7.[/quote]
I was not aware they did anything.
#PIP3935D: Misfire At Idle Due To Leaking Intake Valves - Supplement To 07-06-01-011 - keywords 2.8L 3.5L compression controls cylinder driveability DTC engine excessive head high L52 LK5 leakage leakdown low - (Mar 18, 2008)
Subject: Misfire at Idle due to Leaking Intake Valves - Supplement to 07-06-01-011
Models: 2004-2005 Chevrolet Colorado, GMC Canyon
2006 Chevrolet Colorado, GMC Canyon
and Last 6 of VIN Less than 287698
2006 Hummer H3
and Last 6 of VIN Less than 287591
I think the fix was heads with harder valve seats or something.
Between this and the 20hp difference, I avoided the 2006 models entirely.
[quote=""Duck Vader""]Another win for the XJ. Super easy to get to the fuel injectors. Only hard thing to get to is the fuel pump. Damn thing is in the gas tank.[/quote]
Something good to say about the XJ? Why i never... :rolleyes:
Ive changed the fuel pump and it sucked. Only because you cannot drain the plastic tank. Oh, the fumbling and workout that ensued.
Jeff i would look at injectors first, but it sounds like its a pain to gain access. Not a bad job for $90 and all new injectors though.
