Avalanche
Re: Avalanche
Changed the oil and added some Lucas stuff to it. The tick is almost not noticeable now. I wonder what it is.
Re: Avalanche
If that made a change it might be piston slap.
Re: Avalanche
My thoughts too. LS engines are apparently notorious for it. My engine was more noisy after an oil change but a few hundred miles later its starting to quiet down again. Heard fresh oil change makes it louder unless you add additives. :d ontknow:
Re: Avalanche
[quote=""vr4""]If that made a change it might be piston slap.[/quote]
Is that rebuild time....or it just kind of does it? It Deff made a noise change. If I didn’t know it was there I would never hear it.
Re: Avalanche
Re: Avalanche
I added some snake oil. Lucas oil stuff. I only used half of what it recommended. Crazy stuff, like a stringy oil. The sound is all but gone. Only if you really know to listen for it. I don’t know what it is but I will worry about it after summer and boat season.
Re: Avalanche
Yea snake oil for sure.
Re: Avalanche
My dad drove the avalanche in to get mulch. Never heard any noises. I drive it in to get oil, was quiet....but when I was backing into my house driveway the noise was Deff there. If I had the radio on I prob wouldn’t hear it but it wasn’t fast, just gets louder when it’s straining.
What the freak?
Guy at work who races and does LS motors said “it’s an LS motor it’s lifters” I said you don’t hear it from the top “he said it’s an LS motor it’s lifters”. I showed him the video “he said run higher weight oil”.
I’m guessing it’s not lifters.
Re: Avalanche
The lifters are in the block, not in the heads.
It is probably the lifters. ;-)
Re: Avalanche
Heard it a lot today when cold. Went away when warm.
It doesn’t sound like lifter. But maybe.
Re: Avalanche
It's not a lifter.
Also to change them you gotta pull the heads
Re: Avalanche
What do you think steve? Rod? When warmed up I can’t even hear it. My dad thinks water pump but it’s not leaking and it’s not from the front of the engine.
Re: Avalanche
My vote is still piston slap
Re: Avalanche
[quote=""Duck Vader""]My vote is still piston slap[/quote]
This
Re: Avalanche
[quote=""DCIV""]What do you think steve? Rod? When warmed up I can’t even hear it. My dad thinks water pump but it’s not leaking and it’s not from the front of the engine.
Because piston slap goes away when the pistons heat up, expand, and get to the proper piston to wall clearance.
Re: Avalanche
It’s time, no…past due, I gotta get tires for this thing. They are so dry rotted that I’m playing with safety.
I don’t wanna spend a whole lot. It doesn’t get shit for miles put on it…main worry is always snow.
Is there such a thing as budget tires that are good in snow?
Re: Avalanche
Tire Rack let's you filter for "sever snow" rated tires. That's all I got.
Re: Avalanche
What Chris said. Get severe snow rated tires, they are all seasons, and almost as good in snow as winter tires. We have them on the Explorer, it's great in the snow.
Re: Avalanche
That’s a cool option. Still seems cheapest option is 170’s. Gah tires cost too much.
Re: Avalanche
Since I only put maybe 1k a year on my exploder it lives on proper snow tires. 4 years now and they're less than 25% worn.
