I love it.
I'm the dumbest man on bawc.
Re: I'm the dumbest man on bawc.
Need to confirm but pretty sure my neighbor has a sniper system he took off one of his cars. Wonder if it would work on this. I'll have to see what one he has
Probably have to upgrade the fuel tank, pump and lines to the engine. That's a bit more expensive if you do.
I'm going to look into it. Or maybe I'll swap the carb from the chevelle on if it will work and put the efi on the chevelle for now. Just something to think about
I think the biggest thing you need is a return fuel line. Then you run an in-line pump
It's weird with the 2 tanks apparently. Even the shop said if I try it, they see a lot come in with issues. Especially on the dual tanks.
Looking into it, the carb on the chevelle is more than adequate for the truck. So the question is do I get a similar set up for about $650 on the truck, or do something different on the chevelle and transfer it over? Just needs a Ford kick down plate for $15
Yeah probably because you have to switch the feed and return and people probably don't account for that.
