2001 gmc sierra 2500 slt
Re: 2001 gmc sierra 2500 slt
Well if anyone was reading I talked about it.
I am guessing the original gas peddle plastic wore down to the metal and so he cut a piece of plastic and zip tied it on. I don’t even notice but it is on my things to change.
Right now I need to know if it’s my abs module or a wheel bearing. It’s random. Does abs store codes? My code reader doesn’t pull them even when they happen.
Sweet. I can take it to someone who has a better one as long as it’s stored.
Why, it works and zero people see it. I would rather an abs/wheel bearing problem be fixed first. But I will.
Sounds like you have a long list of fixes my friend. All of which are important.
Eh. No more than any other used truck. You should have seen the ones for the avalanche. It’s all good though.
Floor mats came in today. Fronts fit perfect. I’m thrilled with them for 47 bucks.
Now the back….I didn’t even order the back. It just happen to come with it. But it doesn’t fit well. I will prob cut it and just let it lay over itself.
See how high the middle sits?
I can’t open up the center console drink holder. I don’t know if suburbans are higher? Not a big deal as I said, I only ordered the front, so I will just make a cut and let it lay down.
Also truck still doesn’t smell since I took those other floor mats out and cleaned the carpet!
I did look at it. I think everything is there, and that was just added to give extra space. I think I just have to cut off that block of plastic.
Looks like a way to bring it closer to the user. Must have been a little person.
Found you a new truck... https://www.facebook.com/marketplace/it ... tid=dXMIcH
Our horse transporter runs something similar with a huge horse trailer behind it. He frequently goes up and down the entire east coast and has done some cross country moves as well.Chris GTO TT wrote: ↑Mon Feb 17, 2025 3:53 am Found you a new truck... https://www.facebook.com/marketplace/it ... tid=dXMIcH
I always wanted a kodiak. There is one local-ish with 130k that’s 4x4 and it’s 27k.alienviking wrote: ↑Mon Feb 17, 2025 2:15 pmOur horse transporter runs something similar with a huge horse trailer behind it. He frequently goes up and down the entire east coast and has done some cross country moves as well.Chris GTO TT wrote: ↑Mon Feb 17, 2025 3:53 am Found you a new truck... https://www.facebook.com/marketplace/it ... tid=dXMIcH
Here you go steve.
Codes stored. No active codes but I scanned to see abs codes.
U1064-19
U1301-39
Both those seem to be body control modules and basically they couldn’t report back because things were busy. All online says nothing to worry about.
P1637-19
P1638-19
Basically if an alternator goes bad I have to have the correct one to regulate the voltage. If not then the alternator will not charge and you have to get a different one.
P1626-19
Something with the anti theft and losing voltage while running?
P0463-59
This has to do with the fuel gauge and I am having issues with that always saying low fuel when I start the vehicle. No matter how much fuel. Then the fuel sloshes around some and the gauge works right.
But no stored abs codes!!!! Dangit.
U1064-19
U1301-39
P1637-19
P1638-19
P1626-19
P0463-59
Also all codes cleared and didn’t show back up. Dang abs.
Correct. All seems correct as can be.
Wish I would have wrote down the exact miles. The 8.1’s are known to burn oil. I also have a rear main seal leak. It was half a qt low when I got it. It just now got to adding a qt of oil. Just so I can kind of have an idea.
