And you think, that not using a battery is going to keep it from going dead? Or that since the first once has gone dead from sitting, the second one won’t???DCIV wrote: ↑Sat Dec 07, 2024 8:04 pm The avalanche would go dead in 3 weeks if I didn’t start it. Well, just start it! Well yeah, if it were that easy for me to do then I would have done it. But it’s a couple times a year I would have to. Now this truck maybe better.
Here is what remains. I have two batteries and the second one is really never gonna be used so why not have an option for it to be used? It’s there. It might be simple. It might not. You all are my best option for figuring that out.
I did it! I FINALLY did it!! Dual batteries
Re: I did it! I FINALLY did it!! Dual batteries
I recognize the problem is not using it. I think I even said “well just use it”. Also yes the second would go dead….at hopefully double the time. So maybe 6 weeks. Or maybe it doesn’t because it’s isolated and then you flip a switch and it connects the two for a jump start. At least that’s an option (override switch) on some of the aftermarket isolators. Maybe it’s a fuse for this one.
You can chill though bud.
Agreed. And it’s at the lake so minus a jump box it’s not fun to deal with. But I did buy a jump box.
My point is you’re worrying about something that’s not even a problem on the truck you bought. And something a jump box fixes.
I’m sure having crappy rusted grounds had something to do with it. And I am fixing it. Selling it.
Naw. I got you. I’m just saying, why not have the ability? I honestly like the jump box tucked away in the Lexus. Not having to swap it all up.aaronatstate wrote: ↑Sat Dec 07, 2024 10:17 pm My point is you’re worrying about something that’s not even a problem on the truck you bought. And something a jump box fixes.
Because it’s not something that’s needed at all. Stop trying to Coop things. If your batteries don’t last for a few months without dying, fix the root cause of the problem, don’t band aid it with something else.DCIV wrote: ↑Sat Dec 07, 2024 10:43 pmNaw. I got you. I’m just saying, why not have the ability? I honestly like the jump box tucked away in the Lexus. Not having to swap it all up.aaronatstate wrote: ↑Sat Dec 07, 2024 10:17 pm My point is you’re worrying about something that’s not even a problem on the truck you bought. And something a jump box fixes.
aaronatstate wrote: ↑Sat Dec 07, 2024 10:54 pmBecause it’s not something that’s needed at all. Stop trying to Coop things. If your batteries don’t last for a few months without dying, fix the root cause of the problem, don’t band aid it with something else.DCIV wrote: ↑Sat Dec 07, 2024 10:43 pmNaw. I got you. I’m just saying, why not have the ability? I honestly like the jump box tucked away in the Lexus. Not having to swap it all up.aaronatstate wrote: ↑Sat Dec 07, 2024 10:17 pm My point is you’re worrying about something that’s not even a problem on the truck you bought. And something a jump box fixes.
You all never do things that are out of the ordinary? You all never think something might suit your needs different than what factory thought?
I mean if your intent on doing it then your best bet would be to look up how class C motorhomes wire up their house battery to starter battery booster switch.
See….now we are talking. A battery booster switch!!!!Chris GTO TT wrote: ↑Sun Dec 08, 2024 12:58 am I mean if your intent on doing it then your best bet would be to look up how class C motorhomes wire up their house battery to starter battery booster switch.
Yes, but not something to band aid a problem that can be repaired.
Like putting bigger brakes with viper calipers on my Stealth that makes sense. Changing the wiring on my car because there is a parasitic draw that I don’t feel like fixing properly, does not.
One could argue bigger brakes on a 3/s. Unless tracked the factory brakes are pretty dang good. It’s only in a couple occasions that you would need that….like say…I only need it on a couple occasions when my battery goes dead.
He's not wrong.
The factory brakes are fine for a factory car. Not one with double the horsepower, I make full use of my brakes
You’re still trying to justify a fixable issue, by not fixing said issue, and doing something else instead. Which is just asinine.
I’m trying to make full use of already having the battery. Hopefully this new vehicle will not go dead like the avalanche and it’s a non issue. Just like hopefully you don’t drive to recklessly and need those bigger brakes.
