Electric impacts
Re: Electric impacts
[quote=""tabasco122""]apparently a ft lb is one pound of force applied 1ft away from the fastener. So since it was 2-2.5ft of pipe, it would be about 600-750ftlbs lol.[/quote]
Damn. I thought it would be more.
Subarus - screwed up by wannabe mechanics since 1972.
Actually, the two guys who owned that wrx before me were both engineers and great mechanics lol, i doubt it was overtightened.
[quote=""Chris GTO TT""]What kind of tech is there on air compressors? :scratch: [/quote]
Are you only talking air compressors or the whole lineup, including electric impacts?
[quote=""mjannusch""]A crank bolt put on at around 150 ft/lbs shouldn't take 600+ to remove. ???
I mean think about that - that'd be like me (not a small guy) hanging on the end of a 3' long breaker bar and the bolt not even moving.[/quote]
One would think that... But try to pull off a virgin Honda crank bolt on a timing belt car. Not many impacts can do it.
[quote=""tabasco122""]shit gets tighter over time. The axle nuts on my first wrx i ended up breaking a breaker bar. The second one required my 300lb self bouncing on the end of a 24" cheater pipe. You do the math for how much force that required lol. Spec is 162ft-lbs. The stake on it also increases the torque needed to remove.[/quote]
[quote=""tabasco122""]Another good one is subaru cam gears. Ive stripped that shit out using a breaker bar more times than i can count, even with the proper fitted 10mm hex. Wont do them without an impact now lol.[/quote]
Truth. I've also stripped those bolts out with proper tools. They're fuckin tight.
[quote=""DCIV""]Damn. I thought it would be more.
I'm getting 813 *nm with a 2footer and 1016 *nm for a 2.5footer. This is if you don't jump on it. I *think, again not physics major lol, that you can gain more force by jumping on it because gravity would accelerate you a little bit.
Reason: units fail
[quote=""Toni""]I'm getting 813lbs with a 2footer and 1016 for a 2.5footer. This is if you don't jump on it. I *think, again not physics major lol, that you can gain more force by jumping on it because gravity would accelerate you a little bit.[/quote]
How did you get to those numbers?
It should just be 2ft*300lb for 600ft-lbs, and 2.5ft*300lb for 750ft-lbs shouldn't it?
[quote=""aaronatstate""]How did you get to those numbers?
It should just be 2ft*300lb for 600ft-lbs, and 2.5ft*300lb for 750ft-lbs shouldn't it?[/quote]
Oh yeah, now that you spell it out, it's obvious :lol: OOPS, 813 *nm and 1016 *nm. Which is the same haha. I would do well at NASA :lol:
[quote=""Toni""]Oh yeah, now that you spell it out, it's obvious :lol: OOPS, 813 *nm and 1016 *nm. Which is the same haha. I would do well at NASA :lol: [/quote]
That's why that one Mars rover crashed :lol: Metric vs SAE units :lol:
[quote=""aaronatstate""]That's why that one Mars rover crashed :lol: Metric vs SAE units :lol: [/quote]
https://youtu.be/SiNWnQYXifA
[quote=""vr4""]https://youtu.be/SiNWnQYXifA[/quote]
Miss that guy.
[quote=""ChargerX3""]Are you only talking air compressors or the whole lineup, including electric impacts?[/quote]
Just air compressors
[quote=""Chris GTO TT""]Just air compressors[/quote]
It's not that there's tech in them. It's quality of materials.
That said I have that "ultra quiet" oilless harbor freight 27 gallon and it's quiet.
So far (I've only used it for a day) it's good. Decent airflow and recovery.
Imma get a big husky two stage when I’m ready. Mainly for the warranty.
[quote=""tabasco122""]Imma get a big husky two stage when I’m ready. Mainly for the warranty.[/quote]
My go to will be a 2 stage Ingersoll but I don't have a place for it so I figured this $330 one will do the job. If I get a year I'll be happy
yeah i saw one used for $800 on fb the other day, but im nowhere near ready for one.
Older hf compressors were alright but I’d put them on the lower end of the spectrum nowadays.
[quote=""tabasco122""]i have a video of me taking off staked axle nuts with the dewalt lol[/quote]
[quote=""vr4""]Staked nuts are still no problem for this thing. Rips them right off.[/quote]
https://youtu.be/N4LFWEcjaq4
Dewalt a hair faster???
