Ford Escape first impressions.
Re: Ford Escape first impressions.
I mean other than getting stranded I could start another chris thread!
[quote=""Chris95RT""]Yesss.
Nooo.
I've heard of too many people breaking into the car and driving off with it.[/quote]
I can't leave the key in my Focus, or in our Explorer. It won't let us lock the doors. Maybe it has to be somewhere specific?
[quote=""DCIV""]I mean other than getting stranded I could start another chris thread!
What?
[quote=""aaronatstate""]I can't leave the key in my Focus, or in our Explorer. It won't let us lock the doors. Maybe it has to be somewhere specific?
Same with my Infiniti. I think it's all smart key cars.
Out of curiosity, I tried that with my C7 last summer. I removed the metal key and tried to lock the fob in the car. It wouldn't let me. So I wrapped it in tin foil and put in the corner storage bin in the trunk. Then it let me lock the car. But when I opened it with the metal key, the alarm went off. So that was a little annoying.
I need to figure out how to make a 'dumb' key that I can get wet. Say, when I go to a pool or water park and don't want to get a locker.
What?[/quote]
Meaning if my car was stolen I would get to hunt for another car.
Also my wife’s key fob will let her lock one in her car.
[quote=""Jeff V.""]Out of curiosity, I tried that with my C7 last summer. I removed the metal key and tried to lock the fob in the car. It wouldn't let me. So I wrapped it in tin foil and put in the corner storage bin in the trunk. Then it let me lock the car. But when I opened it with the metal key, the alarm went off. So that was a little annoying.
I need to figure out how to make a 'dumb' key that I can get wet. Say, when I go to a pool or water park and don't want to get a locker.[/quote]
Lol. Drive a 30k plus vehicle...don’t get the 5 buck locker. Love it!
I ran into a similar issue with my Ram. Has keyless entry and start. Went Kayaking with some friends and didnt want to take the fob with me. Luckily Chryslers keys have a metal key that ejects, but there is no key opening in the door, or ignition. There are however key openings for the Ram boxes. Found out I could put my key fob at the furthest rearward point of the box, lock it, and walk off with my metal key without the keyless doors working (fob far enough away from sensors).
Coop wrote:Lol. Drive a 30k plus vehicle...don’t get the 5 buck locker. Love it!
:suspect2:
I discovered by accident that the following scenario will leave you stranded in the CTS:
- Drive to workout location.
- Park and exit vehicle with key fob.
- Close door and it will lock.
- Open hatch to remove bike.
- Leave key fob on the floor of the trunk while changing into cycling shoes.
- Close hatch.
- Curse.
I should try that with the volt since also a GM product.
My Lancer freaks out if I try to lock the FOB in the car. It won't even let me lock it with it running and I have the key outside.
Chris95RT
Post by Chris95RT »
For Ford cars, AA-ron, press the bottom two buttons at the same time to override the don't lock yourself out feature.
[quote=""alienviking""]I discovered by accident that the following scenario will leave you stranded in the CTS:
- Close hatch.
- Curse.[/quote]
The hatch on the Explorer and ST use the FOB, and you can't have this happen either. I tried to lock the fob in the trunk, no dice.
[quote=""Chris95RT""]For Ford cars, AA-ron, press the bottom two buttons at the same time to override the don't lock yourself out feature.[/quote]
On the FOB, or the door keypad? I know the bottom 2 buttons on the door keypad lock the doors, didn't realize it would do it with the FOB in the car though. This is really good information!
Chris95RT
Post by Chris95RT »
Doorpad, trust me- ran into this problem too and it overrides that feature and it's hard to find.
Has to be at the same time though.
Chris95RT
Post by Chris95RT »
And for what it's worth, when the doorpad doesn't work (like if you have interference from another stronger signal at the same frequency) you can slide the key out and pop the cap off the door and let yourself in manually.
There's an RFID in the arm rest, you can place the keyfob in that case. I had to do that once.
But yea, they detect the key in the car (for secure start) and wont let you lock it in there unless you press those bottom two buttons on the door pad.
[quote=""Chris95RT""]And for what it's worth, when the doorpad doesn't work (like if you have interference from another stronger signal at the same frequency) you can slide the key out and pop the cap off the door and let yourself in manually.
But yea, they detect the key in the car (for secure start) and wont let you lock it in there unless you press those bottom two buttons on the door pad.[/quote]
I like my dumb doorpad. Hard wired.
Chris95RT
Post by Chris95RT »
This is hardwired, just capacitive touch hard wired. I meant to actually say hands free door lock.
The doorpad always works if the vehicle has a battery.
[quote=""Chris95RT""]This is hardwired, just capacitive touch hard wired. I meant to actually say hands free door lock.
The doorpad always works if the vehicle has a battery.[/quote]
Oh. I was thinking they went to the wireless they were offering as retrofit options as long as you had rke back in the early 00s.
So if I wanted to get a second key, as I only have one and the valet key. Is there a cheap way to do that? Or just use my buddy at AAA that says it’s about 100 bucks.
[quote=""Chris95RT""]Doorpad, trust me- ran into this problem too and it overrides that feature and it's hard to find.
Has to be at the same time though.[/quote]
Well that is how you lock it from the doorpad outside, so I've done it a few times, just didn't know you could do it with the FOB in the car! That is really good to know.
I had to use the RFID once when the battery got low in my remote. It had enough juice to let me open the door, but not enough for the car to recognize the key was in there. Set the key on the RFID pad, drove straight to Walmart and bought a battery :lol:
