Picked up a rare subaru today...
Re: Picked up a rare subaru today...
well bugeye had some rust that needed to be repaired, while trying to source some metal i found a decent condition forester a guy was about to scrap. picking it up for $200, swapping my driveline over. Thankfully subarus are like legos and the impreza chassis is shared between the two. The forester has 118k miles less than the bugeye lol.
Pretty sure the subframes are the same, no?
[quote=""tabasco122""]Pretty sure the subframes are the same, no?[/quote]
Nope. Turbo has a cutout for the up pipe
not something I can notch out? I know the front looked better than the rear, but ill have to take another look at it.
[quote=""tabasco122""]not something I can notch out? I know the front looked better than the rear, but ill have to take another look at it.[/quote]
Iirc the steering rack is different to accommodate for it too.
See post 38
http://www.rs25.com/forums/f145/83844-t ... log-4.html
See post 38
fuck this project. anxious to get some more done to it, hands are kinda tied until i can send the harness off to get merged.
also, before the shell was scrapped...
https://www.youtube.com/watch?v=QHRsX9lTBRA
[quote=""tabasco122""]fuck this project. [/quote]
Smartest thing I've seen to date
Didn't know subaru's had so much salt in them.
I havent updated this thread in a while. Forester has been sitting at my moms for a couple months. Sent off the wiring harnesses to be merged today. Updating this thread so i can basically stay organized about what needs to be done/installed
Replace coolant hard pipes behind timing cover
Timing kit
TGV deletes
Fuel injectors
Check/replace fuel lines
coolant lines
install aluminum radiator and hope it fits
vac hoses
power steering res/lines
install vf48
install new sensors
walbro pump
shim transmission crossmember
install new axles
install poly bushings
torque every fuggin thing under the car
install wrx rear hub/spindle/brakes
procure front seats (Debating between 370z seats for $100 or m3 Vader seats for free that need to be recovered which would be about $300)
figure out hood scoop situation (cut current hood or buy jdm hood)
install sti topmount
exhaust/o2 sensor
install AC compressor/condenser/lines
boost, wideband, ?? gauges
install light bar
probably add more as i think of it.
soon...
Timing kit
TGV deletes
Fuel injectors
coolant lines
vac hoses
install vf48
install new sensors
walbro pump
install new axles
exhaust/o2 sensor
install light bar
soon...
Finnegan and Fryburger use a larger piece of cardboard and a black sharpie.
If they have no cardboard they just use a quarter panel or fender.
I had it written on the windows but I wiped them off lol.
Soon...
And the toy car?
Idk if it's a prop or if they include it. Will report back Monday lol.
Oh.. That isn't your work? I'm confused now. Is this not before and after pictures of a engine harness?
What's with the toy car drawing in the first photo?
Its just after photos. I had someone else do the harness. The front harness is kinda combined with the body harness on a subaru, they dont have a seperate engine/body harness, and I really didnt feel like fucking it up. I probably could have gotten it functional, but for how much replacements cost, i just paid to have it done.
...3 years later hah.
