Going to need a tow/haul rig
Re: Going to need a tow/haul rig
[quote=""Chris GTO TT""]And GM hung the def tank super low to the ground on the passenger side of the truck.[/quote]
Yep.
DEF is super sensitive to contamination. The last one I pulled was completely caked in mud. It took me almost 30 minutes of cleaning before I was comfortable with opening the tank up to replace the heater (that is also a very common failure).
The more I think about it the more I debate on taking out a loan if I can get a good enough rate. Right now I have $1k set aside a month for extra spending. Once student loans kick in - most calculators say $300 at most, that leaves me with $700 a month to play around with. If I can put just a little bit down on something and keep my payments under $300 or so a month I think it might be worth looking into.
[quote=""vr4""]Possibly. If it were a Ford 6.7 it would probably be 40.
DEF truck though :( [/quote]
https://www.carmax.com/car/22223786
[quote=""Chris GTO TT""]https://www.carmax.com/car/22223786[/quote]
:p
[quote=""vr4""] :p [/quote]
Kinda wanna go look at it lol
Wow that’s a long truck!
[quote=""DCIV""]Wow that’s a long truck!
Yeah crew cab with an 8ft bed makes it huge
[quote=""Duck Vader""]https://www.seattlejeep.com/auto/preown ... /70193039/[/quote]
Which trans did they put in those?
https://www.i-5motors.com/vehicle-detai ... 66CEC59531
Starting to like the idea of the 6.2 f250 more and more lately over the GM.
[quote=""DCIV""]Which trans did they put in those?
Should be the 6L80E
Id prefer that ford I just posted over the chevy I posted before, but the chevy is $10k cheaper. That is a BIG difference.
Yeah I feel like the 6.2 F250 would be great for me too but I kept being told it's a bad idea. I can't find any evidence it's a bad motor though :d ontknow:
It's good from what I've seen too. I just think the difference between the 5.0 and 6.2 isn't worth it in the f150 but it's great for the 250 if you don't need the diesel
[quote=""Duck Vader""]It's good from what I've seen too. I just think the difference between the 5.0 and 6.2 isn't worth it in the f150 but it's great for the 250 if you don't need the diesel[/quote]
Unloaded daily driving I agree but loaded down or towing the 6.2 is worth it in an f150. Especially considering it's more reliable than the Ecoboost
Man I am having nightmares about driving that around in the traffic here, trying to park it etc..
As much as I like the ford I'm not sure if I can justify spending that much. If the gym fails I'd have invested way too much into a truck that's overkill. The chevy at least is cheaper.
[quote=""alienviking""]Man I am having nightmares about driving that around in the traffic here, trying to park it etc..[/quote]
I drive a super long truck…fire truck. I could put that thing anywhere. But man if I had that I would only wanna use it when I needed a truck, not for daily. Lots of these guys talking about daily driving. Gross.
Luckily mine will be a truck truck. No daily. But still needs to be able to handle cross country hauling.
