Avalanche
Re: Avalanche
I'm eventually going to go dual battery. It's on my list of things to do. You will get better results though for power once running with a bigger alternator though.
Re: Avalanche
So GM electrical cannot support power window demand?
Re: Avalanche
[quote=""ChargerX3""]So GM electrical cannot support power window demand?[/quote]
They Deff are slower when battery is lower charge.
Re: Avalanche
[quote=""Duck Vader""]I'm eventually going to go dual battery. It's on my list of things to do. You will get better results though for power once running with a bigger alternator though.[/quote]
I figure I will when this alternator dies. They all do on chevys.
Re: Avalanche
I have a tribeca alternator for my forester i still havent threw on.
Re: Avalanche
[quote=""tabasco122""]I have a tribeca alternator for my forester i still havent threw on.[/quote]
I have one of those HO ones for the vr4 I have yet to put on as well.
Re: Avalanche
its a huge jump for mine, 85-95 amps stock to 135.
Re: Avalanche
I still need to do mine as well. Just haven't gotten around to it yet.
Re: Avalanche
[quote=""Duck Vader""]I still need to do mine as well. Just haven't gotten around to it yet.[/quote]
Because all your doing is fixing stuff. Leave that damn truck alone and put some miles on it.
Re: Avalanche
Can't put miles on it when it's still in the shop. Lol.
Re: Avalanche
:insert unpopular Jeep joke:
Re: Avalanche
[quote=""ChargerX3""]:insert unpopular 3s joke:[/quote]
FTFY
Re: Avalanche
[quote=""ChargerX3""]:insert unpopular Jeep joke:[/quote]
:Insert unpopular jeep opinion: :ick:
Re: Avalanche
:rofl:
Re: Avalanche
*laughs in Ford*
Re: Avalanche
[quote=""Chris GTO TT""]*laughs in Ford*[/quote]
Re: Avalanche
Overland Avalanche!
The Avalanche you see here is almost nothing like the factory model. Where the stock LS put out 285 horsepower and 310 pound-feet of torque, Bill Creech’s truck now makes 325 horsepower and 350 pound-feet of torque and delivers that torque at 2200RPM instead of the original 4600RPM. The aftermarket 4L60E transmission is chock full of severe-duty components, paired to an upgraded torque converter, and cooled by a 30,000-pound trans-cooler. It stops its mass with an oversized Z36 severe-duty brake kit from Power Stop and rolls on 35-12.50/17 General Grabber X3s. It has a welder for emergencies, tools and spares for every eventuality, and a list of upgrades so long it might be easier to tell you what’s still stock. In other words, we have a lot to cover, so let’s get to it.
https://expeditionportal.com/an-overlan ... avalanche/
Re: Avalanche
Hell yeah!
I’ve been making a list of what I wanna do.
It needs new tires
I would like to do gears with a new diff
I want to do the 2wheel low trans options
I want to flash the ecu to adjust for the gears, delete rear O2’s, disable the traction limit power option, and remove speed limiter
I want rear camera / stereo
I want remote start.
That’s a lot!
Re: Avalanche
The camera and stereo are easy. Just get what we got for the Hummer. I can make you a plug and play harness.
Our new Hummer has an aftermarket alarm with remote start. It should be just as easy on your truck.
Re: Avalanche
[quote=""Jeff V.""]The camera and stereo are easy. Just get what we got for the Hummer. I can make you a plug and play harness.
Our new Hummer has an aftermarket alarm with remote start. It should be just as easy on your truck.[/quote]
Yup. And the gears are a neighbor who does stuff like that so really 1000 but then the diff and it can be 400-1000 depending on mild to wild.
The 2wl switch is easy as well.
I think the flash isn’t bad either.
Tires I will get some take offs/used as it just doesn’t get enough miles to justify that.
But I’m still looking at 3k by the time I get done. It’s tempting to sell it while the value is high though.
