Cappuccino - Not only a beverage, but an interesting Japanese Kei Car
Re: Cappuccino - Not only a beverage, but an interesting Japanese Kei Car
vr4 wrote: ↑Fri Aug 18, 2023 10:03 pm I've got a buddy that imports a bunch of acty stuff. Get me a part number and I'll pass it along
You want the OEM part number, or this aftermarket one?
Both would be good
vr4 wrote: ↑Sat Aug 19, 2023 12:13 amBoth would be good
ChargerX3 wrote: ↑Mon Aug 21, 2023 5:07 pm
ChargerX3 wrote: ↑Fri Aug 18, 2023 11:26 pm
Both would be good
I'm so confused..
Sorry I woke up to my computer appearing to not send the post, so i sent again. Double post.
CRPS001 is the one i need from PalSports in Japan. Ill see if i can find the OEM part number.
alienviking wrote: ↑Mon Aug 21, 2023 9:06 pm I'm so confused..
I was too
vr4 wrote: ↑Mon Aug 21, 2023 9:20 pm
I was too
God damnit, what part number do you want??
aaronatstate wrote: ↑Mon Aug 21, 2023 10:11 pm
I was too
NO PART NUMBER FOR YOU!
I think i found the part number.
12610-80F00-000
PULLEY,CRANKSHAFT
https://www.megazip.net/zapchasti-dlya- ... 12-2078312
I needed to get this up and running, so i did some deep cleaning, sanding of the rubber and the metal. I only lost a couple small pieces of rubber, so about 95% of it was still there and still compressed onto the housing well. Actually carved grooves into the metal, to promote adhesion. Then grabbed some Industrial strength glue that i applied to the mating surfaces and put it back together. Then placed it in a vise for 2 days to let cure and try. Then another couple days out in the hot sun. Put it all back together late last week and have taken it to work now 2 times. It appears it might be holding..."knocks on wood".
That's cool. Hopefully it holds up until you can get a proper replacement.
Yea, I probably should order a new one soon.
If my buddy is out tonight I'll pass the numbers along
He said eBay or nengun shouldn't be any problem
Thanks. Yea, ideally purchase from Palsports.
Well in a cruel twist of fate...it happened again. Made it about a mile from work last evening with the AC on and I feel the motor make a quick vibration and I knew immediately what it was. You can even see the glue.
I got home and assessed the damage. All the same rubber was there, but the glue peaced out. It left quite a bit of residue, so i cleaned it off.
Knowing that an overseas pully was easily weeks to months out i started to brainstorm. Looked on youtube as well, but only topics were JB weld and fully welding it up. None of those sounded appealing. The rubber is still fairly tight and functional, but i need to stop it from spinning in place. I also need to stop it from flexing as it follows around the smaller piece.
That's when i got the idea to install 4 pieces of round metal in the shape of a "t". That way i can even out the spacing and keep rotational weight the same. Nails would be the trick. They are just small enough to fit through and can be welded on both sides.
All hammered through...
Now to crack out the dusty MIG welder to weld a bead from the inner pully, to the nail, to the outer. Note that the pully is cast iron, which made this process more difficult. Also didn't help that my welder didn't want to cooperate half the time.
Then the front...
Repainted...
All back together. Although i had to do some more light grinding to make the lip on the timing cover fit behind the balancer. Had a slight rub initially, but quickly cleared up.
I took her for a spin last night and she felt like normal. Also drove it to work today to give her the "real world" test. Hoping this holds together.
Look. I love it. I’m sure it will hold. But I never want to hear about any cooper fixes ever again. Lol
Hahaha I was so thinking "This is a Cooper fix.. or my uncle!"
DCIV wrote: ↑Tue Aug 29, 2023 4:11 pm Look. I love it. I’m sure it will hold. But I never want to hear about any cooper fixes ever again. Lol
See the thing is, this is a temporary fix, not a long term solution, and that's what is different about Cooper fixes.
aaronatstate wrote: ↑Tue Aug 29, 2023 5:29 pm
This, also coop would have been like "I need to fix this permanently, I want to weld it using this coat hanger and jumper cables as a make shift welder, what's the best way to make it work?"
