The wife wants a Tahoe
Re: The wife wants a Tahoe
The struggle is real.
vr4 wrote: ↑Wed Jul 08, 2026 7:54 pm lucid gravity dream edition
A Gravity was parked outside of one of my neighbor's the other day when I came back from a run. Do want.
Started slow before we went to universal. Didn’t really know. Like it wouldn’t even prime the system when you open the door.
Didn’t have time before to get a battery in it so when we got back I swapped a battery.
Also the brakes vibrated something horrible. So I did rotors and pads on the front. But previous pads were fine and rotors were smooth. So I don’t know if I fixed a problem or covered one up.
Also one tire was pretty bad on the outside. Swapped it out today only to drive off without torquing down the spare! So I might have messed up some studs.
I forgot because one of the heater hoses has been getting coolant leak crust on it for a little. And I was only putting on the spare to pull it out of the garage so coolant was easier. By the way. Screw the way GM does the coolant hoses. That was miserable.
