Truck yeah! Dirty Snow Edition
Re: Truck yeah! Dirty Snow Edition
I’m guessing Ford is going the way GM did and making these newer vehicles basically uncrackable except for maybe factory sponsored tunes.
Yep there's rumors of a Ford Performance tune for F150s finally.
I can't even fully figure out how to swap a higher trim BCM into my truck. There's no way I could get anywhere with this new crypto shit.
Do those taillights plug and play on your truck? The LED lights won't swap on to mine without adding some wires. I think I want to do non-BLIS King Ranch lights, but it's gonna take some work to make them fully functional.
Adapter harness and some forscan changes.
I can't help but laugh at Forscan every time. Too damn close to foreskin.
I can do an adapter on mine, but then you end up with weird shit like the running light being connected to the brake light. There's just not enough signal wires to have everything independent like it should be.
Same here.Jason wrote:I can't help but laugh at Forscan every time. Too damn close to foreskin.
Have to be careful with auto correct for sureDuck Vader wrote: ↑Wed Jun 05, 2024 5:27 pm I can't help but laugh at Forscan every time. Too damn close to foreskin.
MPG on the way home from the lake... It actually peaked at 24.8 and probably would have been 25mpg had I not caught a red light on the highway.
PXL_20240616_204027602.MP by christobal65, on Flickr
PXL_20240616_204027602.MP by christobal65, on Flickr- Chris GTO TT
I've seen it be a little over 1mpg optimistic. Even if it's still 'only' 23mpg in reality that's still about what my old legacy was good for.
SO you have calculated it separately at the pump already? My Fords always read a couple mpg high (2-4) mpg depending on type of driving.
My Fords are always very close to what the dash says it seems.
Nice, i use the same app. Good to see your numbers are right on.
Flipitty flappys installed... They don't really move they are the Weather Tech no drill ones.
PXL_20240818_210208826 by christobal65, on Flickr
PXL_20240818_210219290 by christobal65, on Flickr
PXL_20240818_210219290 by christobal65, on FlickrRe: Truck yeah! Dirty Snow Edition
Red light on the interstate?
