The Half Monti
Re: The Half Monti
I’ve been to Colorado I’ve seen the rockys. You all act like you hike them. The Smokey’s are way more hiked.
Re: The Half Monti
[quote=""ChargerX3""]Smokeys are hills in comparison.
Agreed. Stupid big and annoying mountains.
Re: The Half Monti
Had to look them up. At least they are a little over 6,000 ft. At their peak.
We live at 4,500ft.
We live at 4,500ft.
Re: The Half Monti
Short little video from my phone balanced on a rock. Lol. Its not great but its an attempt.
https://youtu.be/xsV-orQd6M0
Re: The Half Monti
Slo-mo was a little silly for such a small puddle, but it looked good otherwise.
Re: The Half Monti
Update:
Had some time this weekend to work on the Monti. As some may already know, I have swapped out the drivers exhaust manifold and the truck is much quieter.
The other project I've been waiting to tackle are my front brakes and calipers. I picked some 2001 Sport Montero's last week and got to work installing them. There are several benefits to the sport calipers and rotors. 1) You get a larger diameter rotor. 2) You get 2 piston calipers vs just the 1.
Here is a picture of the rotors side to side. Max on right.
Install is pretty straightforward with just having to pull everything off the hub. I should have used the stock hubs as they are thicker and don't have a weird taper that cause the Toyota wheels to get pinched on. I later had to grind off the lip you can see in the second pic. Ive also kept the auto hubs for now. I have a set of the rare Aisin manual locking hubs but need to clean and rebuild them to do it right. They are supposidly stronger, but with my small SWB and moderate driving I like staying in the cab and having it work on the fly for now. Good news is that its a quick swap out if I grow tired of them.
Back on and ready for a test drive. These are 18" wheels, and I think the sport rotors help fill in that gap a bit better. Braking is improved as well.
Re: The Half Monti
I really like those wheels.
Re: The Half Monti
Good work and yes. Those wheels are nice.
Re: The Half Monti
With all the snow fall lately I thought it would be fun to play in some before it all melted off.
https://youtu.be/wn_SKO3pHd8
Re: The Half Monti
That was a nice video.
Re: The Half Monti
Thanks. I’m debating on getting back into making some shorts like these more often.
Re: The Half Monti
Nice! Around here the foothills got hammered and local authorities asked everyone to stay away, so I figured I'd be the only one to actually heed the warning lol. Next storm looks to melt most of the snow below 4500ft.
Re: The Half Monti
Thanks. Yea I went up dog valley road where you and I went. I didn’t leave the city though. Lots of people on the dirt road further up. Plenty of emergency rescues this week as people use their gps to circumvent i80 when closed. Little do they realize that dog valley is always worse.
Re: The Half Monti
If you make another one, maybe check out the compression settings. It seemed a bit over-compressed and pixelated in a few spots. But that's just picking nits.
Re: The Half Monti
ugh, i need tires...
Re: The Half Monti
Monti oil pump decided to get the fits. Runs fine and has pressure, but I've got a heavy leak coming from the drivers side of the pump where it meets the block. Pump is pretty new, but im betting its a crap gasket that was supplied.
Its looking like I will have to pull the motor up to drop the pan to slide back off the pump and reinstall the new gasket. Not happy about this...
Re: The Half Monti
Update on the leaking oil pump. Spent Sunday working on it finally since the weather was nice again.
Sucks that you have to remove so many things to get the oil pump off. Remove exhaust, motor mounts, drop pan, lift engine to gain enough clearance to remove oil pickup. Ugh!
Oil pump off. Mind you this was new along with all the other parts of the rebuild. PSI was strong too. Gasket however...pure trash.
How it looked once removed.
The failed paper gasket right around the dowel. The paper was really brittle, but i think the main problem is just how thin the gasket was between the oil passage and the dowel.
New quality gasket installed.
Much more material between the passage and the dowel. Beck and Arnley to the rescue.
Got as far as putting most of everything I took off that day back on. Still need to time, add oil, put all the accessories on. Probably just get the timing belt on with oil next just to make sure it runs and doesn't leak.
Need to get this truck back out on the road!
