The MARO
Re: The MARO
Guy at work drove his today.
Re: The MARO
Nice. Always good to have a little inspiration to look at.
Re: The MARO
Re: The MARO
You got that back together pretty quick. How did all the panel line up?
Re: The MARO
Took some bending and a lot of welding but pretty good. Not perfect but good enough. Rear tail pan and matching up with the trunk lines was the hardest part. Used a ton of clamps and self tapping screws to help. Definitely not great but as my neighbor said, as long as it looks good at 50 50, it's good to go. 50 feet at 50 mph. Lol
Re: The MARO
Yea, bodywork is hard work to perform. Im glad you could get it all back together.
Re: The MARO
Neighbors 67
1st round of primer done.
In 4 days or so I can apply guide coat to see any low spots to add more filler. Then sand and apply 2 more coats of epoxy.
Then 4 days after that I will sand and apply 2 coats of urethane primer and primer sealer.
About a week after that, paint!
Then a week after that, wet sand and buff/polish.
Re: The MARO
great work dude
Re: The MARO
Wow. That’s a lot to paint. I would try to skip/rush all of that.
Re: The MARO
Not going for perfect. See some body work I could fix but honestly we are not building a show car.
Primer is done.
Just need to sand and seal it. Then comes paint.
https://imgur.com/a/SexxK2c
Re: The MARO
Honestly if you are spending the $ on paint then get the body right. You have done quite well for a first full size project. Pull through the home stretch so you don't regret spending an extra couple days/ or week of nailing the body work.
Been there, done that. Hated it!
Re: The MARO
Trim bits need to go on and cleaned but it's done otherwise.
This is right after final clear coat. Needs to cure for at least 12 hours, settle, and let off fumes before we will see how it really looks. Definitely have some orange peel but don't see any fish eyes yet. The roughness you see now will settle out some.
https://imgur.com/a/AJIBjgN
Re: The MARO
But I will be wet sanding, cutting, and polishing everything in the coming weeks
Re: The MARO
holy shit dude
hell yeah
was excited for this when you mentioned it in chat
Re: The MARO
The more it settles the more the orange peel is rearing it's ugly head.
Guess I'll be wet sanding sooner rather than later. Lol
Re: The MARO
wouldnt you want the clear to fully harden first?
Re: The MARO
guess not, looks like 24-48 hours is recommended
Re: The MARO
Looks pretty good so far. Hope you can knock that orange peel down though.
Re: The MARO
It doesn't look as bad now that it dried more if I'm honest, but ya, it's noticeable. I've got sand paper designed for wet sanding up to either 2000 or 3000 grit. I'll hit it in a few days. Need to pick up some more compound and polish too.
Re: The MARO
i like the color
