I know :)
Pft you bought a MOF'ING Hummer! You don't need to plow no stinkin' snow - you drive through it! RAWR!
I know you are joking, but I used to do that shit when I lived in WI. Almost never shoveled the driveway. Pop it in 4wd and just drive through it. Would get a "running" start to power through the pile of snow at the end of the driveway that the plow truck would leave. :lol:
I was a dick.
[quote=""Hans_GZP""]I had Grabbers on my ML500. Hot garbage and didn't last for shit. K02's on my Ram 2500 and they never wore out. You can get 80k miles out of those tires. And never worry about getting stuck in much of anything. The guy I sold the truck to used it for snow plowing. He said the truck would just go through anything. Nothing could stop it. It was much better than his Chevy dump body at plowing snow.[/quote]
Good tire info.
[quote=""vr4""]You would need 4x4 no matter the tire you have on wet grass.[/quote]
[quote=""Chris GTO TT""] :stupid: wet grass is way slicker than most people think.[/quote]
Hummer parked in the exact same spot. Never had an issue.
[quote=""DCIV""]Hummer parked in the exact same spot. Never had an issue.
Full time awd from what I can find
[quote=""vr4""]Full time awd from what I can find[/quote]
Yes but only when slipping happened. You can force it by applying the brake and gas at the same time. I 3 wheeled it on my driveway and could just spin a tire (they said that was a good way to break an axle) until I applied the brakes.
That's like saying the VR-4 is only FWD unless there's slipping... It's not true.
Also isn’t one fully independent suspension vs live rear axle?
[quote=""Chris GTO TT""]That's like saying the VR-4 is only FWD unless there's slipping... It's not true.[/quote]
Okay...I owned one. That’s what it did.
[quote=""ChargerX3""]Also isn’t one fully independent suspension vs live rear axle?[/quote]
This is true and might have helped it. I think the tires were much more aggressive and bigger so bigger contact pad honestly.
I've owned at least 3 vehicles with torsen differentials, I know how they work too. You're latching on to one aspect of them and professing that is how it works always. The very nature of a torsen differential says it must send torque to both sides of the differential unless there is no resistance to one side. The reason they tell you to apply the brakes in the H1 is because it uses triple torsen differentials, and applying the brakes introduces resistance to the free wheel. This forces the torsen to send power to the other side. Toyota's ATRC operates on the same principle.
Yes. So that’s why I could have one wheel spinning. I don’t see what I said as wrong.
[quote=""DCIV""]Yes. So that’s why I could have one wheel spinning. I don’t see what I said as wrong.
[quote=""DCIV""]Yes but only when slipping happened. You can force it by applying the brake and gas at the same time. I 3 wheeled it on my driveway and could just spin a tire (they said that was a good way to break an axle) until I applied the brakes.
You said the H1 was only AWD if it was slipping, which isn't true at all...
If I can free spin one wheel then it’s not awd all the time.
:facepalm:
Anyways Jeff when do the new headlight bulbs arrive and get installed
[quote=""Chris GTO TT""] :facepalm: [/quote]
:werd:
[quote=""DCIV""]If I can free spin one wheel then it’s not awd all the time.
MumRa
Post by MumRa »
it's still AWD, it's just not working.... :lmao:
[quote=""Daetlus""]Sometimes rectal stimulation feels good during intercourse.[/quote]
