Post your car's "To-Do" list!! Come on.. we've all got em!!
Tujin
Re: Post your car's "To-Do" list!! Come on.. we've all got em!!
Post by Tujin »
Oh, and once I get back from a year in Cuba:
Rims
99 Headlights, Novara bumper, 2ndgen sideskirts (unless I find a better option), 99 wing, sail panels, rear garnish, fresh paint
EVO III 16g setup
Fuel
solid x-fercase, CFDS
Nice clutch
Tujin
Post by Tujin »
And a FMIC, obviously
EricVR4
Post by EricVR4 »
Already done in the last couple weekends:
-Install 13Ts
-New oil lines
-Tons of new gaskets/nuts/seals/washers/hoses/etc
-Get crack in front manifold welded
To do (waiting on parts to get finished being made):
-Replace OS/Spool with NBT Quadco OS/Spool
-3 step detail (hasn't been washed in months because it's been broken)
-"re-tune" for whatever I can get out of the 450s and maf-t :p
In the near future:
-Emanage
-Ditch the 450s for some 680s
-Get Adam's ass to Houston to dyno tune it
Get her running to 100%. Damn short I don't know how to fix. ARG!
Then after a couple hundred miles of her running great at 6psi, do two tunes, one at 10psi, the other as high as I can safely take her up to 15psi. I don't want to run over 15psi with stock 9b's and SMIC.
My remaining to do list of future plans (not in order):
'99 front end conversion
'99 sail panels
new tint
FMIC
13T turbos with supporting fuel mods
rear strut bar
coil over suspension
new paint
AWD tranny converted to FWD with Quafie LSD
Then I'm done with the car, my final goal for her is to be between 400-500 whp. Anything higher with FWD will make it to much of a chore to drive IMO.
I'll probably do tint and maybe sail panels this summer. Most everything else will wait until I have another DD so I can rightfully afford the down time.
bluej
Post by bluej »
-new exhaust gaskets
-plugs/wires
-fresh fluids
-find and buy a 94-97 mariner blue miata with a loan
-sell stealth and pay off credit cards
-Profit!
Lady Helmet
Post by Lady Helmet »
Hmm...Clean the inside??
Although, maybe I can bribe Jeremy with baked goods to clean it for me. He did such a great job last time... :p
Jeremy C
Post by Jeremy C »
[quote=""Lady Helmet""]Hmm...Clean the inside??
Although, maybe I can bribe Jeremy with baked goods to clean it for me. He did such a great job last time... :p [/quote]
bah, that was a rush job last time. :p Next nice day that I have off, we'll talk. Give me a couple hours and cleaning supplies, and I'm golden.
G3ML1NGZ
Post by G3ML1NGZ »
- Put in the new vcu and t-case.
- metal y-pipe and a BOV.
- A front lip.
- maybe upgrade turbo's in the end of summer. (haven't decided wich turbo's to use)
- make my own FMIC and piping in school.
- Fix the hemmeroid exhaust.
- replace boost gauge.
- Flush the coolant system.
- sell the ES.
Lady Helmet
[quote=""Jeremy C""]bah, that was a rush job last time. :p Next nice day that I have off, we'll talk. Give me a couple hours and cleaning supplies, and I'm golden.[/quote]
SWEET! I'll even throw in a home cooked meal with the baking goods, just 'cause your awesome.
:kisses:
Steve and I can sit in lawnchairs and supervise :D
Lady Helmet
[quote=""Gatecrasher""]Steve and I can sit in lawnchairs and supervise :D [/quote]
So do you think that deserves some Nessa cooking?
Perhaps we could team up on some things? :)
I'd also like to take a crack at making some sushi. Vira and I made some on Saturday night and it was excellent :D
Jeremy C
Post by Jeremy C »
Me? Need supervised? I'm appalled at the thought!
Lady Helmet
[quote=""Gatecrasher""]Perhaps we could team up on some things? :)
I'd also like to take a crack at making some sushi. Vira and I made some on Saturday night and it was excellent :D [/quote]
That sounds awesome! We never did go get sushi in Toronto. :(
[quote=""Jeremy C""]Me? Need supervised? I'm appalled at the thought![/quote]
oxrageous
Post by oxrageous »
I'm installing Heads Up Display this weekend (factory unit). Unfortunately, that's the one option my car never had that I really wanted. Hence, I'm going to solve that problem.
It looks pretty easy in the writeups. Good luck :)
OBXboost
Post by OBXboost »
[quote=""oxrageous""]I'm installing Heads Up Display this weekend (factory unit). Unfortunately, that's the one option my car never had that I really wanted. Hence, I'm going to solve that problem.[/quote]
I'd like to see a step by step process of you doing it with pictures.
SeanVr4
Post by SeanVr4 »
-tear apart heads
-get heads decked, hot tanked
-put heads backtogether w/ new vss and 99 lifters
-assemble stage 1 shorty w/ all 120k stuff and newly rebuilt heads
-drop motor, trans, new clutch and flywheel into car
-take hubs off and tap out axles
-install new axles
-wire interior gauges some more w/ defi control unit
-install fmic, new koyo rad, 12" flexalite fans, msd coil packs blah blah blah and the list goes on and on
Google > You
-get IC pipes back from welder *DONE*
-put in new autometer wiring harness for one of my nexus gauges *DONE*
-make trim panel to hold 2 gauges in center vent opening *DONE*
-tune aem ems for driveability *tuned for idle right now*
-button up some of the interior *DONE*
-change engine oil twice *DONE*
-wire in radiator fans *DONE*
-detail car
-drive to ocean city, md with what looks to be the only 98 vr4 WHOOT
added
-try to get the car inspected before I leave *got it covered*
-make sure fuel pressure is ok
So far it made 300 awhp at 8 psi and a really rich tune with no real timing advance and only taking it up to 5000 rpms. Fuel map started to get a little hairy after that point so I shut it down. Looks like the IPS 16G setup might make some power if my front turbo stays together. The turbos they sent me were evo 3 GT turbos... those chinese knocks offs *that someone on 3si says they don't use*.
