Mix and match
Re: Mix and match
DCIV wrote: Tue Jun 27, 2023 4:30 pm
Chris GTO TT wrote: Tue Jun 27, 2023 4:21 pm
DCIV wrote: Tue Jun 27, 2023 3:59 pm Loving these ideas.
What about a suburban with a big block. They use to! Now they went diesel.
GM doesn't make a 'big block's anymore besides their current 'small blocks' make more HP and similar amounts of tq as the old big blocks
Do they still do the 502? Maybe not but be a lot cooler if they did.
If they do it's a GM Performance Parts item.
Re: Mix and match
Biggest engine Chevy makes anymore is the 6.2L right? I don’t think they put the 427/7.0L in anything anymore? Either way no “big blocks” like Chris said.
Re: Mix and match
aaronatstate wrote: Tue Jun 27, 2023 4:49 pm Biggest engine Chevy makes anymore is the 6.2L right? I don’t think they put the 427/7.0L in anything anymore? Either way no “big blocks” like Chris said.
Yeah I also think they stopped production on the LS7 427, but it wasn't a true big block it was a punched out small block.
I think the 8.1 is still produced under license by marine manufacturers like Mercury
Re: Mix and match
Looks like they make a 6.6L V8 for their 3500 Chassis cab. Still an LS based engine though.
Re: Mix and match
Well I would make gm make a big block. Then make them put it in. Burb…why….because none of this will happen. Lol.
Re: Mix and match
I'd build an 07+ Escalade EXT (the Avalanche style one) around a 2500 Suburban chassis, and power it with a Duramax.
Re: Mix and match
DCIV wrote: Tue Jun 27, 2023 7:21 pm Well I would make gm make a big block. Then make them put it in. Burb…why….because none of this will happen. Lol.
Just because GM doesn't make them new, doesn't mean you can't get a new GM Big Block...
Re: Mix and match
HHR Panel Van with a Volt drivetrain.
Re: Mix and match
Excursion….but hybrid diesel!!!
Re: Mix and match
I know it's wrong but I don't hate that lol
Re: Mix and match
Jeff V. wrote: Tue Jun 27, 2023 8:35 pm HHR Panel Van with a Volt drivetrain.
I kind of like that idea.
