The Model A
Re: The Model A
Re: The Model A
It was so emotional, I was even tearing up.
Re: The Model A
I need a battery.
Suggestions?
Re: The Model A
Have no idea which one it’s set up for?
Re: The Model A
[quote=""ChargerX3""]Have no idea which one it’s set up for?[/quote]
It’s so factory that it always had a dealer tag.
Re: The Model A
A battery is the last thing you should worry about. You need to go over that whole car before even thinking about applying power to it.
Re: The Model A
I am open to suggestions. But here is what I was thinking.
Drain oil.
Put in 10-30 with some diesel.
Spray and take out spark plugs.
Inspect battery wire and instal battery.
Do compression test.
Drain oil and put in new fresh.
Change the rest of the fluids.
All this time I’m going to be trying to clean the fuel tank, fuel filter, and all those parts.
Then try and start it.
Re: The Model A
I'd inspect all the wiring first. There's a good chance rodents have chewed at least somewhere in all those years.
Are there even fuses on a Model A?
Re: The Model A
Don't forget that you need a 6V battery in there too. Don't hook up any of your 12V stuff.
Re: The Model A
[quote=""mjannusch""]Don't forget that you need a 6V battery in there too. Don't hook up any of your 12V stuff.[/quote]
Correct. And it’s a positive ground. Really has my mind blown.
Re: The Model A
[quote=""mjannusch""]I'd inspect all the wiring first. There's a good chance rodents have chewed at least somewhere in all those years.
Are there even fuses on a Model A?[/quote]
Also have no idea on fuses.
Re: The Model A
Time to scour forums for proper information.
Re: The Model A
[quote=""ChargerX3""]Time to scour forums for proper information.[/quote]
I’ve been reading the manual, it has how to adjust the valves. Lol.
Re: The Model A
I’m sure there is a model A forum you could peruse.
Re: The Model A
Re: The Model A
5 hours later...
Re: The Model A
But does it smell?
Re: The Model A
Maybe...
Re: The Model A
Still smells. Round 2, same thing. If this doesn’t work, then I will roll out the model A and put it inside the car.
Re: The Model A
Its going to smell no matter what.
