PB Blaster
jackhammer
Re: PB Blaster
Post by jackhammer »
[quote=""Monochrome""] discovered the trick to working on an engine while it's still warmed up. :) [/quote]hahaha....iv'e purposefully warmed up an engine prior to working on it a few times. nice trick indeed
Re: PB Blaster
i also refuse to work on rusted cars.
pb blaster is gods gift to 3s owners though.
Zentelis
Re: PB Blaster
Post by Zentelis »
That's weird..I have a can of PB Blaster and many cans of Gibbs. I keep trying the PB Blaster in order to get rid of it and that shit never works. I regularly use Gibbs and bolts come loose a few seconds or minutes later.
I cannot, for the life of me, get PB Blaster to loosen any rusted bolt..bad can?
Tujin
Re: PB Blaster
Post by Tujin »
I've used almost an entire can trying to get these gd bolts that hold the turbos to the manifolds off. No dice.
jackhammer
Re: PB Blaster
[quote=""Tujin""]I've used almost an entire can trying to get these gd bolts that hold the turbos to the manifolds off. No dice.[/quote]Heat is your friend
bluej
Re: PB Blaster
Post by bluej »
[quote=""jackhammer""]Heat is your friend[/quote]
+1
get a can of MAPP.
