Rants...fun
Re: Rants...fun
Well he wants to charge me freaking $286 for a stock replacement one... I would be buying an upgraded one later anyway.
The $700 in labor doesn't bug me in the least. I think you have my thoughts confused. I'm more worried with the $1900 in parts he came up that need to be replaced.
License to /thread Number 5 stupid name... want to be Kevin or Dave!
Re: Rants...fun
WOW! My condolences.
Threads like this makes me glad I do my own work.
If it makes you feel any better, a friend of mine recently had a sop do an engine build on E36 M3, just under $12,000.
- Fya Starta
Re: Rants...fun
[quote=""Daetlus""]Soooo.
Car is in the shop ripped apart.
The $1700 dollar trans rebuild turned into $2600 all of a sudden...joy.
I'd rant more, but I have to...work.[/quote]
My car's at the shop also.
New Clutch and transmission turned out to be $1300 with labor...knowing the mechanic FTMFW.
oxrageous wrote:Great to have you on the boards. Keep in mind a lot of your questions can be answered with the search button - it always worked for me. Welcome!
slagehammer wrote:did you get laid this morning?
Re: Rants...fun
[quote=""Fya Starta""]
...knowing the mechanic FTMFW.[/quote]
- Fya Starta
Re: Rants...fun
[quote=""vegasidol""]
Re: Rants...fun
[quote=""J-Groove""]WOW! My condolences.
-John[/quote]
Not really, all said and done I'll be just under $12,000
-John[/quote]
Re: Rants...fun
-John[/quote]
Never again. I was scared to do it because I'd never done more than replacing rotors and changing oil, but let me tell you, for the amount I'm being raped for right now, I will NEVER let someone else work on my car again. I wish there had been someone around to watch me do this myself.
-John[/quote]
Re: Rants...fun
[quote=""Daetlus""]Never again. I was scared to do it because I'd never done more than replacing rotors and changing oil, but let me tell you, for the amount I'm being raped for right now, I will NEVER let someone else work on my car again. I wish there had been someone around to watch me do this myself.[/quote]
Don't be afraid, the most I had ever done before my motor build was suspension work. I had helped with a motor swap before as well.
The best thing to do is just have faith that you can do it. It will take a lot longer, since I was paranoid about doing everything right the first time plus had a busy school schedule with 21 credits it took me over 5 months to complete.
Re: Rants...fun
I actually bought my first tools that weren't meant for computer repair.
Mechanical tools. I've gone down the path. I'm not planning on turning around.
I can't find that Transaxle tear down PDF that I know exists. I searched 3SI, anyone know where it's linked?
I plan on posting up all the items he's listed for replacement in my Transaxle when I get back from there tonight. I know I won't know what half of it is. I'm hoping for feedback.
Honestly 4 months ago I didn't know what a synchro was much less that it was in my transaxle, or the fact that I had a transaxle and why that was different from a transmission.
If you get bored enough, go look at my first posts on 3SI in November of last year.
I'm learning.
I'm learning.
Re: Rants...fun
[quote=""lawdogg""]Check out stealth316 he has everything you'll need.[/quote]
I'd forgotten the ones he had.
Re: Rants...fun
So..a shop says "$1600 for a rebuild", then tears it apart and wants another $1000 or something?
I bet if you say "no", he'll still charge you $1600 just to put the thing back together.
How the hell people like that stay in business is beyond me..they should be put in jail.
Re: Rants...fun
We already discussed the $700 labor rate. I figured out that the 1st shift fork needs to be replaced. Those are hard enough to get as I understand. I was going to post the whole list of what's being done, but my total is now just under $12,000. I'll have to do it when I get home if I don't end up going to my second job.
- Caffinated Soap
Re: Rants...fun
From $1700 to $2600 to just under $12,000? Did you decide to have the internals platinum coated?
Sometimes I'm really glad I drive an auto. If I need parts, I'll go rob an Eclipse.
The Caffy Factor
Re: Rants...fun
Re: Rants...fun
get your car out of there before i get pissed off, drive out there, bitch slap you for going to a shop, and finish it myself.
Re: Rants...fun
Yeah, I wish.
You have NO idea.
You have NO idea.
- Scopata_Fuori
Re: Rants...fun
My first transmission rebuild, expecting $3500, turned into almost $7,000. That was in 2000, I think. Give or take. And lo and behold, it lasted a tick over 12,000 miles...less than a year and a half.
But something miraculous occurred...was it a wrinkle in time? Or did I just get fucked? My 1993 TT turns out to have an 18 spline transfer case. Which, a short year and a half later, strips the output shaft. And is, by all accounts, an impossibility, by my build date, if I have been informed correctly.
Methinks fuckage occurred. Any guess as to which shop dryreamed me? Here's a hint...An Awful Mess, it was.
Second tranny...turned into almost $5,000, between the dumbasses removing it and re-installing it, having it shipped from TRE, having parts from Kormex sourced...and the new output shaft and upgrading the yoke for a 25 spline.
That's been almost 80k ago...so far, so good.
"Some guys look good in Armani. Some in a ball gag. Too bad they have to open their mouths, to tell the difference." ~~Claudia Balzac
- Scopata_Fuori
Re: Rants...fun
[quote=""vr4""]sound slike you were fucked.
they teased you with lube but didnt provide any.[/quote]
Fucked, hard. And the hard way.
Suspect they got tired of me asking when it would be done (after almost four months) and slapped in a used junk transmission...with an 18 spline. Didn't find out until the next rebuild...barely over a year later.
Bastards.
Bastards.
