Will the gas tank pressurize if I've removed my charc. canister?
jackhammer
Re: Will the gas tank pressurize if I've removed my charc. canister?
Post by jackhammer »
[quote=""lawdogg""]The blue valve is what stops the tank from overfilling?[/quote]No
jackhammer
It's broken because you have a major leak, im guessing at the pump cover since you appear to be missing studs and spewing fuel. Fix it!!!
Heres what makes gas pumps shut off
http://www.sciencetheatre.org/ask_st/122591.html
jackhammer
Well, maybe after you start 5 more threads asking about it, you'll finally get around to doing something about it :lol:
jackhammer
[quote=""lawdogg""]In any event, to answer my original question, Greg if we left that hose uncapped, i assume I will build no pressure in the tank.[/quote]See post 6, i give up, Greg can take over
BillyC
Post by BillyC »
http://www.stealth316.com/2-fuelpump.htm
The blue thing in the picture is the 2 way valve.
BillyC
Post by BillyC »
I've never dropped my tank...but...
Filler neck, overflow, line to cannister, supply and return line.
BillyC
Post by BillyC »
I'm assuming it is the one on top, I've not had to fool with the fuel pump/tank/system on my car yet, so I don't have first hand knowledge of our cars exact setup. I've pulled a few tanks on old beaters we used to scrap...
Yes, you can remove the hard line. I don't know for sure which one it is on the tank, but it shouldn't be too hard to figure out working from the front (where the cannister used to be) towards the fuel tank. :D
BillyC
Post by BillyC »
Most overflow lines just dump...they don't go anywhere.
BillyC
Post by BillyC »
The supply line comes from the top of the tank, as does the line to the vac. cannister. I'm not 100% sure where the return line enters the tank but it would more than likely be full of fuel.
Yes, sometimes you'll get gas fumes in the engine bay with the line still in place. That is one reason to remove the line, or reroute it. I added a soft line and ran it out the front on the car near the underbody splash guards.
You are correct about the return line. It also keeps the fuel circulating so it doesn't get hot and cause a vapor lock.
BillyC
Post by BillyC »
You can't see where the leak is coming from? It shouldn't be too hard to see fuel shooting out at 40psi?
