The 944
Re: The 944
[quote=""stealthee""]You were in PA and didn't stop by to say hello? :mad:
:lol: [/quote]
He was at the dragon and didn’t tell anyone either.
Re: The 944
Mike wrote:Never really. I've gotten used to driving with a low splitter from the vette. Besides the Vette airdam is designed to flex when dragged.
I've got a carbon fiber OEM copy stage 2 splitter on it. The little rubber air dams are still the lowest thing on the car, but because of the angles the damn splitter catches on every little incline. I'm amazed I can make it up the ramp into the lot at work.
Re: The 944
Mine is bolted and riveted to the bumper, per factory spec.
I've got this damn gutter at the end of my driveway and matter how I angle the car, I always grind it just slightly, twice a day. :grumble:
I made the mistake of going up Steve's driveway in MI and damn near ripped the thing off when I went to back out.
Re: The 944
That's exactly why there's no splitter on my C7... It looks cool, but easy to end up damaged.
Still have to put my Z06 grille in.
Re: The 944
You could get the stage 1 splitter. It's made of flexible ABS rather than fiber, and it's cheap enough that it's basically disposable. I've seen where people have painted them carbon flash. It looks pretty good.
Re: The 944
How much ground clearance you have under the splitter? I have less than 4" on the volt so I scrape that son of a bitch all the time. Luckily it is just a rubber flap that has break away parts that snap back together if you push it too hard.
Re: The 944
I broke my front lip the other day, was sad, but it's a cheap one.
Re: The 944
[quote=""tabasco122""]I broke my front lip the other day, was sad, but it's a cheap one.[/quote]
Sorry about your face bro.
Re: The 944
But does it still vape?
Re: The 944
idk, i left it in louisiana
Re: The 944
completely my fault too. Neighbor parked close to the line, so victoria parked close to the line, so i had to park closer to the curb, cut the wheel too early when backing up and smacked the curb.
Re: The 944
[quote=""tabasco122""]completely my fault too. Neighbor parked close to the line, so victoria parked close to the line, so i had to park closer to the curb, cut the wheel too early when backing up and smacked the curb.[/quote]
You bite the curb?! You never bite the curb.
