Oh no, what have I done... Part 2
Re: Oh no, what have I done... Part 2
Subaru:
Service
Until
Broke
And
Remain
Underwater
Ordered one from import image racing :barfaway: but the good news it will be here by Friday afternoon according to FedEx. It was like $2 extra for their 2 day shipping... worth it!
Engine is in the car mated to the transmission bolted up and motor mounts bolted in place. I took absolutely zero pictures today, but I think my dad has a few.
I posted pictures. Just saying.
I'm aware, but I'd have to take pictures to be able to post pictures :dontknow:
Went out into the garage just for you Cooper Doodles ...
ImagePXL_20231203_042016971 by christobal65, on Flickr
ImagePXL_20231203_042029056 by christobal65, on Flickr
I can just see you all blue taping that thing lol. I’m surprised you don’t have the rubber covers.
I like this wrx, I would want that pike peaks look. That lifted look. Man I bet that would be fun.
Getting closer...I like.
Just went to remove the rear O2 sensor and the bung snapped off :MikeB:
Picked up a new bung at the auto parts store and my dad will weld it on this week sometime
Well that is convenient. :)
I've been plugging away at getting it all hooked up during my lunches and breaks this week. I also put in a few hours on Sunday night and again tonight. I've been working slow mostly to try and stay clean. Tonight I got everything hooked up and connected I can until I get the downpipe back and installed. I'll probably pick up coolant and startup oil tomorrow, and then start filling it up with fluids.
Like I put in Shout I filled it with coolant using my cooling system tester/vacuum filler. Also got it filled with my startup oil, downpipe, and intercooler installed. All that's left is the battery and then cranking it with the crank sensor unplugged to build up oil pressure, and then starting it :ohnoes:
Passenger side intake cam shaft seized so the engine is coming back out :MikeB: :sob:
Chris GTO TT wrote: Sat Dec 09, 2023 5:28 am Passenger side intake cam shaft seized so the engine is coming back out :MikeB: :sob:
How’s that possible??
Did you try and start it and find this out? How did you come to this conclusion? Did you use assembly lube on it?
DCIV wrote: Sat Dec 09, 2023 1:22 pm
Tried to start it last night. I followed the FSM it just called for engine oil.
aaronatstate wrote: Sat Dec 09, 2023 12:26 pm
2 main possibilities: 1. There was some minor undetectable by hand burr on a journal where the cam rides. 2. Apparently the FSM for 02 has a typo calling for the wrong torque spec on the cam tower bolts, so it may be over torqued. I followed the 02 FSM to a T for this stuff.
:hug:
:hug2: thanks I'm pretty dejected today. I was really feeling like I was finally going to get to drive it and now I'm taking it back apart :(
