Avalanche
Re: Avalanche
Re: Avalanche
[quote=""Duck Vader""]Buy a Jeep WJ with a H.O 4.7[/quote]
Need a truck bed. I use it all the time. Literally. All the time.
Re: Avalanche
I really felt like shit getting stranded with my baby. Literally.
Re: Avalanche
[quote=""DCIV""]Need a truck bed. I use it all the time. Literally. All the time.
I was being a jackass with this comment. The Jeep WJ with the HO 4.7 is arguably the worst Jeep ever made.
Re: Avalanche
I know it says 07, but you would think it would apply to 04 as well?
https://static.nhtsa.gov/odi/tsbs/2012/ ... 4-7690.pdf
Re: Avalanche
No. It's not the same engine.
Re: Avalanche
No
[quote=""Duck Vader""]I was being a jackass with this comment. The Jeep WJ with the HO 4.7 is arguably the worst Jeep ever made.[/quote]
Ok good
[quote=""Jeff V.""]No. It's not the same engine.[/quote]
Yep. My comment for Dodge is if the engine size ends in 7 it's garbage.
2.7, 3.7, 4.7, and to a somewhat lesser extent 5.7 and 6.7
Re: Avalanche
7's my lucky number. :d erp:
Re: Avalanche
[quote=""vr4""]
2.7, 3.7, 4.7, and to a somewhat lesser extent 5.7 and 6.7[/quote]
My neighbor has a 2 year old Ram with the 5.7 Hemi and it sounds like shit I can hear the ticking over his obnoxiously loud exhaust.
Re: Avalanche
Lol you’re just imagining things. You know you only hear it while you’re sitting inside your Toyota. ;)
Re: Avalanche
I can hear it over the sound of my Toyota falling apart :ick:
Re: Avalanche
:rofl:
Re: Avalanche
Probably manifold leaks. Super common. Easy fix
Re: Avalanche
[quote=""vr4""]Probably manifold leaks. Super common. Easy fix[/quote]
Chevy 5.3 has a tick they say is exhaust studs as well. Mine doesn’t have it yet but I’m sure if I keep it then it will.
Re: Avalanche
New fuel pump installed and avalanche back up and going.
200 pump, 100 instal charge.
Re: Avalanche
Anyone, prob Steve, know anything about these servo’s to help out the GM trans?
2nd gear corvette servo.
https://www.sonnax.com/parts/2430-2nd-g ... -servo-kit
4th gear super hold.
https://www.sonnax.com/parts/2473-4th-g ... -servo-kit
Re: Avalanche
Called up the local trans place I trust. They do recommend the corvette servo. Said with the past it would cost about 150-200 and take about an hour for them to put in.
Very tempted.
Re: Avalanche
That’s going to be the first of another dozen parts that will need fixing before you are done.
Re: Avalanche
[quote=""ChargerX3""]That’s going to be the first of another dozen parts that will need fixing before you are done.[/quote]
Well what sucks is there are TONS of things I kind of wanna do. Like this.
https://m.youtube.com/watch?v=7Jv9NGN7y3w&feature=share
I could put this thing in the garage and keep doing stuff to it. But the 2/3 shift on these things is lazy as balls.
Re: Avalanche
It's an Avalanche. Just drive it.
