The Model A
Re: The Model A
[quote=""ChargerX3""]You get to park that at the fire house?[/quote]
No. I keep it in the trailer, and take it to work, unload it, work on it, then load it up, and take it back to the in-laws. But with it getting cold I cant pull the fire engine out, so prob gonna have to take it to the house.
Re: The Model A
Just putting links in.
https://www.mikes-afordable.com/product/M8591SSZ.html
Also apparently fans have to be fitted to the shaft
https://www.mikes-afordable.com/product/M8600AK.html
Re: The Model A
Ordered a leakless kit to turn my water pump into that, a new fan, exhaust gaskets….apparently the rear can sag and you will never get it right again. I don’t want a new one. I like this one. It may get welded up and redone. Lol.
Re: The Model A
Happy thanksgiving from the firehall guys!!!
Had to take the hood off to get the water pump off.
Water pump off
If you look close you see where they pressed the fan blades together and it can come apart and hurt people.
Exhaust off for new gaskets.
Just a small leak on the end honestly isn’t bad but I will make it all flat and redo it.
It’s hard to tell but not only did two of the 4 studs come out, but one is one size smaller nut than the others.
Waiting on parts to rebuild the water pump and gaskets to do the intake and exhaust.
Water pump off
Re: The Model A
Tomorrow is gonna be fun.
Re: The Model A
Huge update.
The water pump
Other side.
Shaft out
Cleaned but not all the way apart.
These were a pain to get out.
Going back together.
This is pre zerk fittings. It was a spring and flat piece. Pretty cool honestly.
This is what they sent me to replace it. Um no. First there is still shavings in it and second, no spring or anything.
Back together.
The water pump
Other side.
Shaft out
Back together.
Re: The Model A
Making all surfaces flat.
Making flat.
Where the exhaust leak was coming from. And how dirty it was.
Cleaned and one gasket on.
Back together. With belt and water pump.
And
https://youtu.be/diFfWPv0RoY
BAM!!!
Re: The Model A
That looks a lot nicer
Re: The Model A
[quote=""Chris GTO TT""]That looks a lot nicer[/quote]
Its hard not to sandblast and paint. But I know it would just take away from what it is. So much is untouched. It really was more fun than I thought it would be.
Re: The Model A
That is really, really cool, Coop. Congrats
Re: The Model A
[quote=""Jeff V.""]That is really, really cool, Coop. Congrats
I drove it around the station 3 times. Shut it down, add fuel, start up, go again. Well it got dinner time .stopped for 2 hours. Went to start it back up and it wouldnt. It eventually sputtered, but its done this before and we dont know why. Dont know if I should let it run out of fuel if sitting for that long ..dont know if its some sort of vapor lock, or what. Its frustrating though. Makes me worry when it does start to drive that I will drive it somewhere and then be screwed when I need to go home.
But thank you!
But thank you!
Re: The Model A
Oh man I missed the video because I was posting as you were. That's so awesome you got it running and out for a drive!
Re: The Model A
[quote=""Chris GTO TT""]Oh man I missed the video because I was posting as you were. That's so awesome you got it running and out for a drive![/quote]
Pretty cool isnt it! It was deff more fun than I imagined.
Re: The Model A
It went from being an unmoving garage decoration for however decades to moving under its own power in the brief time you've had it. That's a win by any reasonable standard. You'll figure out how to make reliable enough given a little more time.
Re: The Model A
[quote=""Jeff V.""]It went from being an unmoving garage decoration for however decades to moving under its own power in the brief time you've had it. That's a win by any reasonable standard. You'll figure out how to make reliable enough given a little more time.[/quote]
Re: The Model A
[quote=""ChargerX3""]That thing lave patches of rubber?
or oil?[/quote]
So, it hasnt leaked any engine oil. I havnt checked the trans or rear but Im sure once I have to fill them then it will. Ive been looking at garage mats to put down under it in the trailer.
I will. I want it drivable by warm weather. I think its doable. I need to find something harsher to clean out the gas tank quicker.
or oil?[/quote]
Re: The Model A
The old and new lower radiator pipe
Little paint booth
Love the drain valve
Little info about the “A”
I thought mine was an early 30’s as only in early 30’s did they do this extra metal strip on the fenders. This info about the valve just adds to that.
Tomorrow I take the model A in and hopefully finish up the coolant system.
Gonna focus on the gas tank tomorrow as well. Because after that all I need to do is the trans and rear end fluid and tires.
Little paint booth
Re: The Model A
Oh. Also I am going to redo the stock clamps, just the worm clamps will work for now.
