Replacing my 03 cobra
Re: Replacing my 03 cobra
this is what ive found in a short search for z26s.aaronatstate wrote: ↑Sun Apr 12, 2026 9:42 pm Any of the 1001 pads will fit in those calipers. EvoX 1001A pads are thicker, but they’ll still work with a 32mm thick rotor (this is what I run on the stealth)
evox pads are 13.4mm z261001 32mm rotors
civic type r pads are 14.0mm z261001b 32mm front rotors. Im suspecting these calipers are significantly wider though as the hardware included seemed to indicate this.
2013 camaro 14.5mm z261474 31.9mm rotors but pads have a goofy damper on them that will in no way clear my wheels. id have to cut them off.
cadillac xts 15mm z261836 30mm rotors
there was a fair amount of room between the pads and rotors before stepping on the pedal so im suspecting the 15mm pads will fit.
Sorry it was the Viper pads that were thicker (17.3mm thick) vs. the EvoX pads at 13.4mm thick.
I have Z261001 pads in my Viper calipers, and I can confirm that the Viper Caliper and the EvoX caliper were the same overal width. I had Porterfiled Pads at one point as well, and their 1001 pads are all 14.9mm thick, and say they fit a whole lotta different vehicles.
The Civic Type R caliper is a different design than the older 4 piston Brembo calipers that were all similar to the F40 calipers (though still uses the same pad apparently).
