Oh no, what have I done... Part 2
Re: Oh no, what have I done... Part 2
Only swap I could realistically do is an STI swap, but I'd need a whole car for that. I'm more likely to take this engine/car and swap it into a different Subaru... like an 00-03 outback/legacy wagon.
https://www.jxbperformance.com/products ... er-upgrade
That's an interesting idea on upgrading the carrier bearing.
They make something like this for 3S now too. https://3000gtstealthsolutions.com/prod ... tealth-gto
Everyone I know who has gotten them, likes them a lot.
Yeah its an interesting concept, leave the factory bearing alone but give it better support. I'm interested since my chasis has 252k on it so i'm sure the carrier bearing support rubber is well past done.
Yeah typically it's the rubber that gets destroyed (hence why you can move them all around).Chris GTO TT wrote: ↑Mon Nov 06, 2023 9:05 pm Yeah its an interesting concept, leave the factory bearing alone but give it better support. I'm interested since my chasis has 252k on it so i'm sure the carrier bearing support rubber is well past done.
Pretty much, but i'd be able to run full stage rallies like WRC after getting an FIA cage lol
Just depends on the class i'd want to run it (assuming I had the time or the money). I mean talent aside lol
The reality is all you need to run staged rally in the US is the basic safety equipment (cage, seat, harness etc.) and an otherwise stock car is fine. To run in 4wd Open class like the Subaru Rally Team run by Vermont Sports Car, yes it'd take a lot more to be fully prepared.
Can confirm, have friends that rallied
In my spare time
I got the heads on and torqued down today.
Made lots of progress today. I installed the cam covers, timing set including new cam gears on the RH side, timing covers, new crank pulley, exhaust manifold, up pipe turbo, intake manifold, new turbo inlet pipe, coolant reservoir and lots of other odd and ends. I'm kinda at a stopping point because when I was replacing the turbo inlet pipe the evap purge vacuum lines and part of the valve broke so I have to order another $80+ of parts from Subaru. My current plan is to try and get it on the road before the end of the year. I'd love to have it running and driving before the 2 year anniversary of buying it.
You know if this was my post and I didn’t put pictures I would get shit.
Just saying, were the pics?
This is a lot of effort now
PXL_20231010_010906046 by christobal65, on Flickr
PXL_20231010_010911747 by christobal65, on Flickr
PXL_20231112_005428218 by christobal65, on Flickr
PXL_20231112_005432858 by christobal65, on Flickr
PXL_20231116_223904135 by christobal65, on Flickr
PXL_20231116_223913290 by christobal65, on Flickr
PXL_20231118_193725526 by christobal65, on Flickr
PXL_20231118_202203794 by christobal65, on Flickr
PXL_20231119_023646312 by christobal65, on Flickr
PXL_20231119_023651680 by christobal65, on Flickr
PXL_20231119_023651680 by christobal65, on Flickr- Chris GTO TT
Oh and even though i'd have to pull the intake manifold again I really want this new re-manufactured harness https://iwireusa.com/collections/iwire- ... ne-harness however I'm not super interested in spending another $500ish right now.
Sweet one of the $30 parts I needed the PO had ordered and left in the hatch for me.. Score lolChris GTO TT wrote: ↑Sun Nov 19, 2023 5:30 am Made lots of progress today. I installed the cam covers, timing set including new cam gears on the RH side, timing covers, new crank pulley, exhaust manifold, up pipe turbo, intake manifold, new turbo inlet pipe, coolant reservoir and lots of other odd and ends. I'm kinda at a stopping point because when I was replacing the turbo inlet pipe the evap purge vacuum lines and part of the valve broke so I have to order another $80+ of parts from Subaru. My current plan is to try and get it on the road before the end of the year. I'd love to have it running and driving before the 2 year anniversary of buying it.
