That V8 tho...
Re: That V8 tho...
This fuel pump thing is starting to piss me off.
I can't find anything regarding flow rates for the OE pumps in the GM trucks. It seems like everyone just says "put a Walbro 255 in it" :lol:
I also thought about getting the 2010 FlexFuel capable pump. I don't ever plan to run E85, but it should give me all the capacity I'd need. Only problem with that is, it's nearly double the cost of the 08-09 pump and you can only get it from GM. There are no generics.
I'm just going to put the stock pump in it and deal with it later....if I even actually go through with the engine swap.
Re: That V8 tho...
You've had enough engine swaps for a while.
Re: That V8 tho...
I thought this was interesting. 2010 South African model. (They built RHD models in South Africa). Added a tow shackle on the left. Dual exhaust. V8 badge instead of Alpha. Global taillights and reflectors. Ridiculous tires.
Re: That V8 tho...
Jesus those tires!!
Re: That V8 tho...
37" tires. Looks like a fair amount of mods.
2010 Hummer H3 V8 Adventure:
INSTALLED: 37" Maxxis Treps, 4" Rancho suspension lift, 2" Custom Body Lift, 2" wheel spacers, 2nd D shackle at back, Cranked Torsion Bars, ARB Bullbar, Warn 9500XP winch, synthetic winch rope, Lightforce 240 HID spots, Bullydog Watchdog parameter monitor, aftermarket TPMS, Safari Snorkel, African Outback Roof-rack, roof mounted long range tank, Maggiolina rooftop tent, 60W solar panel, Eazy awning, Performance exhaust and headers, cold air intake, Hood Louvre handles,custom UC skid-plate, rear Hunner skids, load bay box, PCMofNC software upgrade, 4.1 to 4.56 diffs re-geared, duel battery system with D250S solar charging, trailer power cable connect, Hummer roof mounted off-road lights, Trucool 40 000 BTU ATF cooler, motorised AMP Research side steps.
Build thread. Looks like he started with a white 07. Lots of nice photos.
https://www.hummer4x4offroad.com/forum/ ... mmer-build
Re: That V8 tho...
Those are some bad-ass tires!
Re: That V8 tho...
Had a somewhat productive weekend.
Got the step boards, radio and backup camera removed from the orange truck. We still need to figure out the wheel situation though. The pressure sensors in the silver truck's wheels are dead. I had hoped it was just a failed relearn, but nope. After an hour of testing I'm convinced they're dead. We don't want to put crappy tires and a tire warning light on the orange truck while we try to sell it. We had a line on a local set of wheels and tires that had been on Craigslist for a couple months now, and now we know why. The guy is completely worthless when you want to actually give him money. So now we're leaning towards just selling it as is and dealing with the tires on the silver truck later.
The step boards don't fit with the rock rails. No big surprise there. I've got an idea to make them work though. That'll be a project for later.
I checked the oil pressure sensor. Looks like that's bad. Add it to the next Rock Auto list.
Gonna need an AC evaporator. The whole seal flange is snapped right off the pipe. How does that even happen? It's only $60, but I'm gonna need to pull the dash to replace it. Fortunately it's not too complicated.
I did actually accomplish something though. I replaced the trashed door hinge bushings. That was a pain in the ass. But the door doesn't flop around any more. I kind of wish I had at least driven it around the block while the door was off. But I was tired and just wanted to get it done.
I'll get the parts ordered and hopefully knock out most of this next weekend. I'd start the fuel tank and dash teardown this week, but Vira wants to take it on a short family outing on Thursday.
Re: That V8 tho...
Progress is good!
Re: That V8 tho...
Getting a lot done I see. That ac problem is odd.
Re: That V8 tho...
[quote=""Jeff V.""]Gonna need an AC evaporator. The whole seal flange is snapped right off the pipe. How does that even happen? It's only $60, but I'm gonna need to pull the dash to replace it. Fortunately it's not too complicated.[/quote]
Someone snag the line when they were working on it before?
Re: That V8 tho...
So does the Humvee have the option to have just low gear on the rear wheels? If so I bet that’s how we figure out the relay that’s needed.
Re: That V8 tho...
An actual Humvee, or my truck? Mine is full time AWD. No 2WD at all. Humvee....no clue. But I doubt it's got anything in common with your Avalanche.
Re: That V8 tho...
[quote=""Jeff V.""]An actual Humvee, or my truck? Mine is full time AWD. No 2WD at all. Humvee....no clue. But I doubt it's got anything in common with your Avalanche.[/quote]
I meant your hummer. My bad. Yours is awd? I thought you had selections for 4wd. Maybe that’s an h2 I’m thinking about.
Re: That V8 tho...
It's full time AWD with hi-lock and lo-lock transfer case modes.
Re: That V8 tho...
[quote=""Jeff V.""]It's full time AWD with hi-lock and lo-lock transfer case modes.[/quote]
It's like the Ridgeline transmission. Does it disable the rear wheels and cruise in FWD mode too?
Re: That V8 tho...
[quote=""Monochrome""]It's like the Ridgeline transmission. Does it disable the rear wheels and cruise in FWD mode too?[/quote]
Doubt it, since it's got a longitudinal V8. If anything it might disable the front wheels and cruise in RWD mode.
Re: That V8 tho...
None of that nonsense here. The only way to disable the front or rear axle is to drop the driveshaft. There's even a warning under the hood about doing smog tests on an AWD dyno.
Re: That V8 tho...
When you put it in 4lo does it lock the center differential or is that a separate button?
Re: That V8 tho...
It's got 3 transfer modes. 4 Hi (normal every day mode) 4 hi-lock (locked center, high speed) and 4 Lo-lock (locked center, low crawler gear). The off road / adventure pack has a 4:1 low range. The regular H3s are 2.64:1.
Re: That V8 tho...
So it won't do what Coop wants where he can be in 4lo and drive on pavement
