It's finally done
Re: It's finally done
Blacked out there bar? I like
Blacked bar and bow tie. Just left a little around the edge of the bow tie untouched so it would stand out.
Tore off the outside door trim panel things. Thought I still had a 3m erase wheel but don't so have a bunch of two sided tape shit stuck on the sides. Lol. Ordered a new wheel and will clean it up and get pics towards the end of the week.
Keep debating on if I want to remove the side steps. Don't use them.
I also kind of want to swap tires with the jeep. Lol. Both are same size but jeep ones are nicer.
[quote=""Duck Vader""]I also kind of want to swap tires with the jeep. Lol. Both are same size but jeep ones are nicer.[/quote]
Swap them!
Poor Jeep.
Don't worry about the jeep. Will be driving it a couple times a week to keep it in decent shape.
14.4 mpg. 75% city.
Radio and sub are in. Just need to make some adjustments to the amp. Also putting in a dash cam and installing rear view camera tonight.
Will post pics after all done.
Back up camera.
Unit playing Android auto
Subwoofer under back seat
Dash cam
And finally, any ideas on how to get rid of these lines where the side trim molding was?
Used 3m eraser wheel to remove tape, goof off and goo gone to remove remaining residue. These outlines are still there.
Anyone who goes to a junk yard, I'll pay you if you find a drivers side door latch assembly, mine works except for the electric signal to the truck that lets it know the door is open. So when I open the door the lights don't come on and the radio keeps playing.
Cheap part, but rather try oem.
Not sure if it's the assembly or wire connection somewhere.
Need to get my hands on a fsm
Is the radio stuff done? It looks like it’s missing it’s trim?
I took pics mid install
Interesting.
Found a service bulletin that might help with the door. Going to see if I can splice some wires together and see what happens.
Damn. I wish I knew you needed parts. I was at two junkyards today.
Let me know how it ends up. There's plenty around.
Tab says replace latch first. Then try splice
I think this is what I need.
https://www.amazon.com/dp/B00GUGRSQW/re ... PEbC3MA6E8
Just don't want to spend $140 and it not work.
I'll see what I can do.
Checked pick n pull for the local stuff. Didn't see much. Problem is there are a variety of types depending on what you have.
