Truck Yeah!
Re: Truck Yeah!
Yeah it sounds pretty good once you really dip into the throttle but you have to get above 3500 rpm for it to wake up volume wise.
Re: Truck Yeah!
[quote=""stealthee""]Run a parasitic draw test and/or put a maintainer on it.[/quote]
Hooked up the multimeter today and it seems like it is drawing almost 3 amps just sitting
Seems like a fairly common issue with these trucks from the search I did.
Re: Truck Yeah!
Gotta wait for everything to shut down. Not sure about newer stuff but for years Ford's didn't shut the gem module down for 45 minutes. You can watch the meter and see the draw go from over an amp to about .015 right as 45 minutes hits.
Re: Truck Yeah!
I like my magnaflow for what it's worth. Some drone at certain rpms but very mild and usually really quiet until you get on it.
Re: Truck Yeah!
[quote=""vr4""]Gotta wait for everything to shut down. Not sure about newer stuff but for years Ford's didn't shut the gem module down for 45 minutes. You can watch the meter and see the draw go from over an amp to about .015 right as 45 minutes hits.[/quote]
So do I leave the multimeter connected and on for 45+ minutes and then check?
Re: Truck Yeah!
[quote=""Chris GTO TT""]So do I leave the multimeter connected and on for 45+ minutes and then check?[/quote]
Yes. Connect the meter in series (how I assume you're doing it) in addition to a jumper wire so the meter can turn off.
With mine I haven't had a problem but some meters will open the circuit when you turn it back on. That resets the timer.
Anyways with jumper connected make sure meter is on and reading (probably 0), disconnect jumper wire being sure not to disturb meter connections. You'll see your reading at that point.
Re: Truck Yeah!
Oh. And muffler delete that bad bitch. Long tubes and a supercharger. You'll love it
Re: Truck Yeah!
[quote=""vr4""]Oh. And muffler delete that bad bitch. Long tubes and a supercharger. You'll love it[/quote]
At first I was like yes....then I was like....that escalated quickly....then I agreed you will love it.
Re: Truck Yeah!
I'll let you guys PayPal me the money for that set up.
Re: Truck Yeah!
Before you do this, just swap in the GT500 supercharged 5.2L and dual clutch transmission!
Re: Truck Yeah!
I'm about 90% sure this is my problem as I don't get the key in ignition chime... https://youtu.be/gCMyEHaDZqM
Re: Truck Yeah!
It's draining the battery enough cause it to not start after a day or so.
I actually had to jump it at noon today when I was at the office for something.
Re: Truck Yeah!
Damn. Trade it in.
Re: Truck Yeah!
Is it the original battery? If so its probably on its last legs. I had to replace the Lancer's battery last winter. It made it 8 years so I couldn't complain too much I guess.
Re: Truck Yeah!
[quote=""stealthee""]Is it the original battery? If so its probably on its last legs. I had to replace the Lancer's battery last winter. It made it 8 years so I couldn't complain too much I guess.[/quote]
Stickers and everything on it makes me think it's newer.
Re: Truck Yeah!
[quote=""Chris GTO TT""]Stickers and everything on it makes me think it's newer.[/quote]
Brand of battery, and how old?
Wife used to source batteries for Wal-mart, and their BEST battery is only guaranteed to last 3 years, and their entry level battery is only guaranteed to last a year.
Re: Truck Yeah!
Motorcraft, but I don't see a sticker with a date on it.
