Avalanche
Re: Avalanche
Wonder what the biggest tire I can fit under this avalanche is.
Re: Avalanche
I'm sure you could fit some 44" tires if you get creative enough with a Sawzall :lol:
Re: Avalanche
Well got the new shocks, he said it helped but didn’t fix the issue. He was right. Didn’t fix the issue. Tires have plenty of tread, I sent a pic go Jeff, at least enough tread to not be this issue.
I’m thinking ball joints? I know there was a little but if gap on the sway bar end links but this is a jarring, not an annoying rattle.
Wonder what a place would charge me to replace the ball joints.
Re: Avalanche
#shittychevyindependentfrontsuspensionsonlargertrucks
Re: Avalanche
[quote=""ChargerX3""]#shittychevyindependentfrontsuspensionsonlargertrucks[/quote]
QFT
Re: Avalanche
Yup. Truth.
Re: Avalanche
Re: Avalanche
[quote=""DCIV""]https://www.carid.com/energy-suspension ... rl=2362843
Saving for later
Thats just the start...
Re: Avalanche
I'd worry more about control arm bushings than sway bar bushings
Re: Avalanche
[quote=""Chris GTO TT""]I'd worry more about control arm bushings than sway bar bushings[/quote]
100%.
Re: Avalanche
Just making a list of things I would like to do to the avalanche.
Drivers door window switch-it’s a known issue to cause my seat heater to have a mind of its own.
Tint- it sits outside. It needs tint
Gauge cluster- gas said almost empty...half tank to fill up.
Back up camera- make it easier to hook up the boat as I’m almost always alone.
Remote start- yeah I love having it working at the fire hall and it being warm when I get in.
I’m sure there are others but this is my short list.
Re: Avalanche
Looks like its time to trade in on an H3.
Re: Avalanche
[quote=""ChargerX3""]Looks like its time to trade in on an H3.[/quote]
I know right!!! I just did an oil change on the avalanche, I didn’t even do that for the Humvee! Have to say I went past a white H3 today, 15k...I liked it.
Re: Avalanche
I think it’s fate
Re: Avalanche
Coop will need the Alpha with the adventure package. V8, lockers at all 3 diffs, and a super low range transfer case.
H3T Alphas hold their value surprisingly well. Most of them are in the low to mid 20s.
Re: Avalanche
[quote=""Jeff V.""]Coop will need the Alpha with the adventure package. V8, lockers at all 3 diffs, and a super low range transfer case.
H3T Alphas hold their value surprisingly well. Most of them are in the low to mid 20s.[/quote]
:evillaugh:
Re: Avalanche
My avalanche is this, just needs the front locker!
Re: Avalanche
[quote=""DCIV""]My avalanche is this, just needs the front locker!
But more weight, length, fuel, and repairs. ;)
Re: Avalanche
[quote=""ChargerX3""]But more weight, length, fuel, and repairs. ;) [/quote]
Hauls more, has a truck bed, was cheaper....and yes more repairs.
Re: Avalanche
You should have bought a Honda Ridgeline.
